Datasheet SLM (Songle Relay)
ManufacturerSongle Relay
DescriptionAutomotive Relay 20A/35A
Pages / Page2 / 1 — SLM. Series. AUTOMOTIVE. RELAY. 20A/35A. 2. X. 3MAX. A. Features. 15.5M. …
File Format / SizePDF / 4.5 Mb
SLM. Series. AUTOMOTIVE. RELAY. 20A/35A. 2. X. 3MAX. A. Features. 15.5M. X. ·35A. switching. capability. A. M. 2. ·Ambient. temp.range. upto. 125℃. 5. 2. ·Dustproof. and
Datasheet SLM Songle Relay
SLM Series AUTOMOTIVE RELAY 20A/35A 2 X 3MAX A Features 15.5M X ·35A switching capability A M 2. ·Ambient temp.range upto 125℃ 5 2 ·Dustproof and sealed type available Ordering Information Contact Rating SLM-12-S-1- R-C Contact arrangment A /B/C A/B/C Voltage drop ≤200mV Contact arrangment Contact material Silver alloy:AgCdO、AgSnO2、AgNi R:resistor/D:diode Without:without parallel components Paralle c l oil components Contact rating 20A/35A 14VDC 1.PCB type Without: QC terminal Max switching voltage 30VDC Version S sealed / F dustproof Max switching current 35A (Resistive 1 4VDC) Construction 12VDC/ 24VDC Min contact load 1A 6VDC Coil Voltage Electrical endurance (frequency: 900 ops/h) 1x10 5ops Part number endurance Mechanical 7 1x10 (frequency: 18000 ops/h) ops Characteristics Coil Data ( 20 at ℃) Insulation system Class B / Class F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ(500VDC) W VDC ± Ω 10% Ω voltage voltage allowable Dielectric Between contacts 550VAC 1minute 1. 5 12 96 Strength and coil Between open 1. 7 12 96 680 contacts 550VAC 1 minute 70%Max 10%Min 130% 1. 5 24 384 Operate time(Under nominal voltage) ≤10ms 1. 7 24 384 2700 Release time(Under nominal voltage) ≤10ms Humidity 85% RH(20℃) Ambient Temperature -40℃~+125℃ Functional 98m/s
²
Shock resistance Destructive 980m/s
²
Vibration resistance 5Hz
22.3Hz 10mm ( Double amplitude) Approx 20g Weight Construction u D stproof and Sealed type Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
