Datasheet SLNE (Songle Relay)
ManufacturerSongle Relay
DescriptionAutomotive Relay 30A
Pages / Page3 / 1 — SLNE. Series. 30A. 27MAX. Features. X. ·30A. switching. capability. A. M. …
File Format / SizePDF / 6.4 Mb
SLNE. Series. 30A. 27MAX. Features. X. ·30A. switching. capability. A. M. 3. 5. ·1. Form. A. and. 1. Form. B. type. avaliable. ·Rainproof. type. X. A. M. 2. .5. 9MA. 2. X. 2. Ordering
Datasheet SLNE Songle Relay
SLNE Series 30A 27MAX Features X ·30A switching capability A M 3 5 ·1 Form A and 1 Form B type avaliable ·Rainproof type X A M 2 .5 9MA 2 X 2 Ordering Information Contact Rating SLNE-12-1-R-A Contact arrangment A /B Voltage drop ≤200mV A/B Contact arrangment Contact material Silver alloy:AgCdO、AgSnO2、AgNi R:resistor/D:diode Without w : ithout parallel components Contact rating 30A 14VDC Paralle c l oil components 1.PCB type 2.Plastic bracket, QC terminal Max switching voltage 30VDC 3.Metal bracket, QC terminal Without: QC terminal Version Max switching current 35A (Resistive 14VDC) 12VDC/ 24VDC Min contact load 1A 6VDC Coil Voltage Electrical endurance (frequency: 900 ops/h) 1x10 5ops Part number 7 endurance Mechanical 1x10 (frequency: 18000 ops/h) ops Characteristics Coil Data ( 20 at ℃) Insulation system Class B / Class F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ(500VDC) W VDC ± Ω 10% Ω voltage voltage allowable Dielectric Between contacts 550VAC 1minute 1. 5 12 96 Strength and coil Between open 550VAC 1minute 1. 7 12 96 680 contacts 70%Max 10%Min 130% 1. 5 24 384 ≤ Operate time(Under nominal voltage) 10ms 1. 7 24 384 2700 Release time(Under nominal voltage) ≤10ms Humidity 85% RH(20℃) Ambient Temperature -40℃~+125℃ Functional 98m/s
²
Shock resistance Destructive 980m/s
²
Vibration resistance 5Hz
22.3Hz 10mm ( Double amplitude) Approx 36g Weight Construction Rainproof Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2 页 3
