Datasheet VLDB1232, VLDTG1232 (Vishay) - 8
ManufacturerVishay
DescriptionDome Lens SMD LED
Pages / Page10 / 8 — VLDB1232.., VLDTG1232.. TAPING AND REEL DIMENSIONS. VLD.1232G. VLD.1232R. …
Revision1.0
File Format / SizePDF / 238 Kb
VLDB1232.., VLDTG1232.. TAPING AND REEL DIMENSIONS. VLD.1232G. VLD.1232R. COVER TAPE PEEL STRENGTH. LABEL
VLDB1232.., VLDTG1232. TAPING AND REEL DIMENSIONS VLD.1232G VLD.1232R COVER TAPE PEEL STRENGTH LABEL
in millimeters:
VLD.1232G
(gullwing) Unreel direction X Ø 60 min. Tape position coming out from reel 1500 pcs / reel 2 ± Ø 178 ± 2 0.5 Ø 13 ± 0.5 +2 12.4 0 Label posted here Technical drawings according to DIN specifications
in millimeters:
VLD.1232R
(reverse gullwing) Unreel direction X Ø 60 min. Tape position coming out from reel 1500 pcs / reel 2 ± Ø 178 ± 2 0.5 Ø 13 ± 0.5 +2 12.4 0 Label posted here Technical drawings according to DIN specifications
According to DIN EN 60286-3
Standard bar code labels for finished goods
0.1 N to 1.3 N The standard bar code labels are product labels and used 300 ± 10 mm/min for identification of goods. The finished goods are packed in final packing area. The standard packing units are labeled 165° to 180° peel angle with standard bar code labels before transported as finished goods to warehouses. The labels are on each packing unit and contain Vishay Semiconductor GmbH specific data. Rev. 1.0, 12-Feb-2019
8
Document Number: 80003 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
