Datasheet MMBT3906 (Nexperia) - 7
ManufacturerNexperia
DescriptionPNP switching transistor in a SOT23 plastic package. NPN complement: MMBT3904.
Pages / Page9 / 7 — PACKAGE OUTLINE. Plastic surface mounted package; 3 leads. SOT23. …
Revision17032003
File Format / SizePDF / 356 Kb
PACKAGE OUTLINE. Plastic surface mounted package; 3 leads. SOT23. DIMENSIONS (mm are the original dimensions). UNIT. max
PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT23 DIMENSIONS (mm are the original dimensions) UNIT max
NXP Semiconductors Product data sheet PNP switching transistor MMBT3906
D B E A X HE v M A
3
Q A A1
1 2
c e1 bp w M B Lp e detail X 0 1 2 mm scale
DIMENSIONS (mm are the original dimensions) A1 UNIT A b e v max. p c D E e1 HE Lp Q w
1.1 0.48 0.15 3.0 1.4 2.5 0.45 0.55 mm 0.1 1.9 0.95 0.2 0.1 0.9 0.38 0.09 2.8 1.2 2.1 0.15 0.45
REFERENCES OUTLINE EUROPEAN ISSUE DATE VERSION PROJECTION IEC JEDEC EIAJ
97-02-28 SOT23 TO-236AB 99-09-13 2003 Mar 18 6 Document Outline Features Applications Description Marking Pinning Quick reference data Limiting values Thermal characteristics Characteristics Package outline Data sheet status Disclaimers
