Datasheet MAX6627 (Maxim) - 3
ManufacturerMaxim
DescriptionRemote ±1°C Accurate Digital Temperature Sensors with SPI-Compatible Serial Interface
Pages / Page10 / 3 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. …
Revision7
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. LOGIC INPUTS (CS, SCK). LOGIC OUTPUTS (SDO)
Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS LOGIC INPUTS (CS, SCK) LOGIC OUTPUTS (SDO)
MAX6627/MAX6628 Remote ±1°C Accurate Digital Temperature Sensors with SPI-Compatible Serial Interface
(3.0V ≤ VCC ≤ 5.5V, -55°C ≤ TA ≤ +125°C, unless otherwise noted. Typical values are at TA = +25°C, VCC = +3.3V, unless otherwise noted.)
Logic Input Low Voltage V 0.3 x IL V V CC Logic Input High Voltage V 0.7 x IH V V CC Input Leakage Current ILEAK VCS = VSCK = GND or VCC 1 µA
LOGIC OUTPUTS (SDO)
Output Low Voltage VOL ISINK = 1.6mA 0.4 Output High Voltage VOH ISOURCE = 1.6mA VCC - 0.4 V
TIMING CHARACTERISTICS
(Note 2, Figure 2) Serial-Clock Frequency fSCL 5 MHz SCK Pulse Width High tCH 100 ns SCK Pulse Width Low tCL 100 ns CS Fall to SCK Rise tCSS CLOAD = 10pF 80 ns CS Fall to Output Enable tDV CLOAD = 10pF 80 ns CS Rise to Output Disable tTR CLOAD = 10pF 50 ns SCK Fall to Output Data Valid tDO CLOAD = 10pF 80 ns
Note 1:
TRJ is the temperature of the remote junction.
Note 2:
Serial timing characteristics guaranteed by design. www.maximintegrated.com Maxim Integrated │ 3
