LT1993-4 AC ELECTRICAL CHARACTERISTICS TA = 25°C, VCCA = VCCB = VCCC = 5V, VEEA = VEEB = VEEC = 0V,ENABLE = 0.8V, +INA shorted to +INB (+IN), –INA shorted to –INB (–IN), VOCM = 2.2V, Input common mode voltage = 2.2V, no RLOADunless otherwise noted. SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS en100M Input Referred Noise Voltage Density 2.55 nV/√Hz 1dB Compression Point 17.8 dBm Note 1: Stresses beyond those listed under Absolute Maximum Ratings Note 4: The LT1993C-4 is guaranteed to meet specified performance from may cause permanent damage to the device. Exposure to any Absolute 0°C to 70°C. It is designed, characterized and expected to meet specified Maximum Rating condition for extended periods may affect device performance from –40°C and 85°C but is not tested or QA sampled reliability and lifetime. at these temperatures. The LT1993I-4 is guaranteed to meet specified Note 2: As long as output current and junction temperature are kept below performance from –40°C to 85°C. the Absolute Maximum Ratings, no damage to the part will occur. Note 5: This parameter is pulse tested. Note 3: The LT1993C-4 is guaranteed functional over the operating Note 6: This parameter is guaranteed to meet specified performance temperature range of –40°C to 85°C. through design and characterization. It has not been tested. TYPICAL PERFORMANCE CHARACTERISTICS Frequency ResponseFrequency Response vs CLOADFrequency ResponseRLOAD = 400RLOAD = 400RLOAD = 100 18 27 18 VIN = 50mVP-P 15 UNFILTERED 24 UNFILTERED OUTPUTS 15 UNFILTERED 10pF OUTPUTS OUTPUTS 12 21 12 5pF 9 FILTERED 18 9 FILTERED OUTPUTS 1.8pF OUTPUTS 6 15 6 0pF GAIN (dB) GAIN (dB) GAIN (dB) 3 12 3 VIN = 50mVP-P VIN = 50mVP-P 0 UNFILTERED: RLOAD = 400Ω 9 0 UNFILTERED: RLOAD = 100Ω FILTERED: RLOAD = 350Ω FILTERED: RLOAD = 50Ω –3 (EXTERNAL) + 50Ω (INTERNAL 6 –3 (EXTERNAL) + 50Ω (INTERNAL FILTERED OUTPUTS) FILTERED OUTPUTS) –6 3 –6 1 10 100 1000 10000 1 10 100 1000 10000 1 10 100 1000 10000 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 19934 G01 19934 G02 19934 G03 Third Order IntermodulationThird Order IntermodulationThird Order IntermodulationDistortion vs FrequencyDistortion vs FrequencyDistortion vs FrequencyDifferential Input, No RLOADDifferential Input, RLOAD = 400Differential Input, RLOAD = 100 –10 –10 –10 2 TONES, 2V 2 TONES, 2VP-P COMPOSITE 2 TONES, 2V –20 P-P COMPOSITE –20 –20 P-P COMPOSITE 1MHz TONE SPACING 1MHz TONE SPACING 1MHz TONE SPACING –30 –30 –30 –40 FILTERED –40 FILTERED –40 FILTERED OUTPUTS OUTPUTS OUTPUTS –50 –50 –50 –60 –60 –60 –70 UNFILTERED –70 –70 UNFILTERED OUTPUTS UNFILTERED OUTPUTS –80 –80 OUTPUTS –80 THIRD ORDER IMD (dBc) THIRD ORDER IMD (dBc) THIRD ORDER IMD (dBc) –90 –90 –90 –100 –100 –100 –110 –110 –110 0 20 40 60 80 100 120 140 0 20 40 60 80 100 120 140 0 20 40 60 80 100 120 140 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 19934 G04 19934 G05 19934 G06 Rev B 6 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Application Package Description Revision History Typical Application Related Parts
