Datasheet ADL5601 (Analog Devices) - 4
Description50 MHz TO 4.0 GHz RF/IF Gain Block
Pages / Page16 / 4 — ADL5601. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 323 Kb
ADL5601. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADL5601 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
FREQUENCY = 900 MHz Gain 14.3 15.3 16.5 dB vs. Frequency ±50 MHz ±0.01 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.22 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.02 dB Output 1 dB Compression Point (P1dB) 18.0 19.0 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 43.0 dBm Second Harmonic POUT = 0 dBm −57.6 dBc Third Harmonic POUT = 0 dBm −78.7 dBc Noise Figure 3.7 dB FREQUENCY = 2000 MHz Gain 14.2 dB vs. Frequency ±50 MHz ±0.08 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.27 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.03 dB Output 1 dB Compression Point (P1dB) 17.5 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 34.2 dBm Second Harmonic POUT = 0 dBm −41.9 dBc Third Harmonic POUT = 0 dBm −67.3 dBc Noise Figure 4.5 dB FREQUENCY = 2600 MHz Gain 13.4 dB vs. Frequency ±50 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.20 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.04 dB Output 1 dB Compression Point (P1dB) 16.0 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 30.7 dBm Second Harmonic POUT = 0 dBm −46.4 dBc Third Harmonic POUT = 0 dBm −65.4 dBc Noise Figure 4.7 dB FREQUENCY = 3500 MHz Gain 12.9 dB vs. Frequency ±50 MHz ±0.06 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.32 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.05 dB Output 1 dB Compression Point (P1dB) 14.2 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 26.7 dBm Second Harmonic POUT = 0 dBm −41.0 dBc Third Harmonic POUT = 0 dBm −62.4 dBc Noise Figure 5.5 dB FREQUENCY = 4000 MHz Gain 12.1 dB vs. Frequency ±50 MHz ±0.11 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.50 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.05 dB Output 1 dB Compression Point (P1dB) 12.7 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 24.7 dBm Second Harmonic POUT = 0 dBm −41.0 dBc Third Harmonic POUT = 0 dBm −59.7 dBc Noise Figure 6.1 dB Rev. A | Page 4 of 16 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
