Datasheet ADL5601 (Analog Devices) - 9
Description50 MHz TO 4.0 GHz RF/IF Gain Block
Pages / Page16 / 9 — Data Sheet. ADL5601. TYPICAL PERFORMANCE CHARACTERISTICS. +25°C. OIP3. …
File Format / SizePDF / 323 Kb
Data Sheet. ADL5601. TYPICAL PERFORMANCE CHARACTERISTICS. +25°C. OIP3. –40°C. , d B. +85°C. , OI. P1dB. +25°C –40°C. OIP. , P. GAIN. GA ,. 0.4. 0.8. 1.2
Data Sheet ADL5601 TYPICAL PERFORMANCE CHARACTERISTICS +25°C OIP3 –40°C , d B +85°C , OI P1dB +25°C –40°C OIP , P GAIN GA , 0.4 0.8 1.2
Data Sheet ADL5601 TYPICAL PERFORMANCE CHARACTERISTICS 45 26 45 +25°C 40 24 40 ) OIP3 m 35 B 22 35 –40°C , d B 30 +85°C (d 20 30 3 ) ) P m m 25 B B , OI d (d 18 25 ( B 3 dB 20 d 1 P1dB P1 +25°C –40°C OIP , P GAIN 16 20 IN 15 GA , 14 15 F 10 +85°C N 5 NF 12 10 0 10 5
20 06 0
0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0 0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
0 9- 9- 21
FREQUENCY (GHz)
821 08
FREQUENCY (GHz)
0 Figure 3. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency Figure 6. P1dB and OIP3 vs. Frequency and Temperature
16.0 44 900MHz –40°C 42 15.5 40 700MHz 15.0 38 350MHz +85°C 2000MHz 14.5 36 +25°C ) 34 ) 14.0 m B d B 32 140MHz 50MHz ( d 13.5 ( IN 3 30 2600MHz GA 13.0 OIP 28 26 12.5 24 3500MHz 12.0 22 4000MHz 11.5 20 11.0 18
07
04
–10 –8 –6 –4 –2 0 2 4 6 8 10 12 14 16
0 -0 9- 19 21
FREQUENCY (GHz) P
82
OUT PER TONE (dBm)
08 0 Figure 4. Gain vs. Frequency and Temperature Figure 7. OIP3 vs. Output Power (POUT) and Frequency
0 7.5 7.0 –5 6.5 –10 B) ) 6.0 d B ( d +85°C ( 5.5 RS –15 E T S22 URE E 5.0 IG +25°C –20 F E 4.5 ARAM S12 IS -P –40°C S NO –25 4.0 S11 3.5 –30 3.0 –35 2.5 0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0
21
08 0 -0 9- 19
FREQUENCY (GHz)
21 82
FREQUENCY (GHz)
0 08 Figure 5. Input Return Loss (S11), Output Return Loss (S22), and Figure 8. Noise Figure vs. Frequency and Temperature Reverse Isolation (S12) vs. Frequency Rev. A | Page 9 of 16 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
