Datasheet HMC754S8GE (Analog Devices) - 6
DescriptionGaAs HBT High Linearity Push-Pull Amplifier, 75 Ohm, DC - 1 GHz
Pages / Page10 / 6 — HMC754S8GE. GaAs HBT HIGH LINEARITY. PUSH-PULL AMPLIFIER, 75 Ohm, DC - 1 …
File Format / SizePDF / 867 Kb
HMC754S8GE. GaAs HBT HIGH LINEARITY. PUSH-PULL AMPLIFIER, 75 Ohm, DC - 1 GHz. Absolute Maximum Ratings. Outline Drawing
HMC754S8GE GaAs HBT HIGH LINEARITY PUSH-PULL AMPLIFIER, 75 Ohm, DC - 1 GHz Absolute Maximum Ratings Outline Drawing
HMC754S8GE
v00.0409
collector Bias voltage (vcc) +5.5 vdc rf input power (rfin) +10 dBm elecTrosTATic sensiTive Device 8 Junction Temperature 150 °c oBserve HAnDlinG precAUTions continuous pdiss (T = 85 °c) 1.21 W (derate 18.69 mW/°c above 85 °c) T Thermal resistance m 53.5 °c/W (junction to ground paddle) s storage Temperature -65 to +150 °c operating Temperature -40 to +85 °c k - esD sensitivity (HBm) class 1c c lo in B
Outline Drawing
A r & G e iv r s - D r ie noTes: lif 1. leADfrAme mATeriAl: copper AlloY 2. Dimensions Are in incHes [millimeTers] p 3. Dimension Does noT inclUDe molDflAsH of 0.15mm per siDe. m 4. Dimension Does noT inclUDe molDflAsH of 0.25mm per siDe. A 5. All GroUnD leADs AnD GroUnD pADDle mUsT Be solDereD To pcB rf GroUnD.
Package Information
part number package Body material lead finish msl rating package marking [3] Hmc754s8Ge roHs-compliant low stress injection molded plastic 100% matte sn msl1 [2] Hmc754 XXXX [1] max peak reflow temperature of 235 °c [2] max peak reflow temperature of 260 °c [3] 4-Digit lot number XXXX Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8 - 6
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
