Datasheet ADL5534 (Analog Devices)
Description | 20 MHz TO 500 MHz IF Amplifier |
Pages / Page | 16 / 1 — 20 MHz to 500 MHz. Dual IF Amplifier. Data Sheet. ADL5534. FEATURES. … |
Revision | B |
File Format / Size | PDF / 435 Kb |
20 MHz to 500 MHz. Dual IF Amplifier. Data Sheet. ADL5534. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Fixed gain of 20 dB
20 MHz to 500 MHz Dual IF Amplifier Data Sheet ADL5534 FEATURES FUNCTIONAL BLOCK DIAGRAM Fixed gain of 20 dB T1 Operation up to 500 MHz IN1 FOU RF NC NC R Input/output internally matched to 50 Ω 16 15 14 13 Integrated bias control circuit OIP3 of 40 dBm at 70 MHz NC 1 12 CLIN1 P1dB of 20.4 dBm at 70 MHz BIAS NC 2 11 NC Noise figure of 2.5 dB at 70 MHz ADL5534 NC 3 10 NC Temperature and power supply stable BIAS NC 4 9 NC Single 5 V power supply 5 6 7 8 T2 IN2 NC IN2 RF CL FOU R
001
NC = NO CONNECT
06836- Figure 1.
GENERAL DESCRIPTION
The ADL5534 contains two broadband, fixed-gain, linear The ADL5534 is fabricated on a GaAs HBT process. The amplifiers and operates at frequencies up to 500 MHz. The device is packaged in a 16-lead 5 mm × 5 mm LFCSP that device can be used in a wide variety of equipment, including uses an exposed paddle for excellent thermal impedance. cellular, satellite, broadband, and instrumentation equipment. The ADL5534 consumes 98 mA of current per amplifier on The ADL5534 has a fixed gain of 20 dB, which is stable over a single 5 V supply, and is fully specified for operation from frequency, temperature, power supply, and from device-to- −40°C to +85°C. device. The amplifiers are single-ended and internally matched A similar amplifier, ADL5531 (available from Analog Devices, to 50 Ω. Only input/output ac-coupling capacitors, power supply Inc.) is the 20 dB gain single-channel version. Fully populated decoupling capacitors, and an external bias inductor are evaluation boards for both the ADL5531 and ADL5534 are required for operation of each amplifier. available.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2008–2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Using Baluns to Combine Both Amplifiers into a Single Amplifier ADC Driving Application Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
