Datasheet ADL5531 (Analog Devices) - 5
Description20 MHz TO 500 MHz IF Gain Block
Pages / Page12 / 5 — Data Sheet. ADL5531. ABSOLUTE MAXIMUM RATINGS Table 3. ESD CAUTION. …
RevisionC
File Format / SizePDF / 511 Kb
Data Sheet. ADL5531. ABSOLUTE MAXIMUM RATINGS Table 3. ESD CAUTION. Parameter. Rating
Data Sheet ADL5531 ABSOLUTE MAXIMUM RATINGS Table 3 ESD CAUTION Parameter Rating
Data Sheet ADL5531 ABSOLUTE MAXIMUM RATINGS Table 3. ESD CAUTION Parameter Rating
Supply Voltage on RFOUT 5.5 V Input Power on RFIN 10 dBm Internal Power Dissipation (Paddle Soldered) 600 mW θJA (Junction to Air) 103°C/W Maximum Junction Temperature 150°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C ESD Rating—Human Body Model ±2 kV Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. C | Page 5 of 12 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
