Datasheet ADL5541 (Analog Devices) - 3
Description20 MHz to 6 GHz RF/IF Gain Block
Pages / Page13 / 3 — Data Sheet. ADL5541. SPECIFICATIONS. Table 1. Parameter. Test …
File Format / SizePDF / 272 Kb
Data Sheet. ADL5541. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADL5541 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
VPOS = 5 V and TA = 25°C, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
OVERALL FUNCTION Frequency Range 20 6000 MHz Gain (S21) 900 MHz 15.2 dB Input Return Loss (S11) Frequency 500 MHz to 5 GHz −12 dB Output Return Loss (S22) Frequency 500 MHz to 5 GHz −10 dB Reverse Isolation (S12) −19 dB FREQUENCY = 20 MHz Gain 17.6 dB Output 1 dB Compression Point 18.3 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 38 dBm Noise Figure 3.3 dB FREQUENCY = 100 MHz Gain 15.7 dB Output 1 dB Compression Point 19 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 37 dBm Noise Figure 3.9 dB FREQUENCY = 500 MHz Gain 14.7 15.1 15.5 dB vs. Frequency ±50 MHz ±0.15 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.1 dB vs. Supply 4.75 V to 5.25 V ±0.01 dB Output 1 dB Compression Point 19.9 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 3 dBm per tone 44 dBm Noise Figure 3.5 3.7 dB FREQUENCY = 900 MHz Gain 14.9 15.2 15.4 dB vs. Frequency ±50 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.15 dB vs. Supply 4.75 V to 5.25 V ±0.01 dB Output 1 dB Compression Point 19.7 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 40.8 dBm Noise Figure 3.5 3.7 dB FREQUENCY = 2000 MHz Gain 13.9 14.7 15.4 dB vs. Frequency ±50 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.17 dB vs. Supply 4.75 V to 5.25 V ±0.01 dB Output 1 dB Compression Point 16.3 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 39.2 dBm Noise Figure 3.8 4.0 dB FREQUENCY = 2400 MHz Gain 13.9 14.5 15.1 dB vs. Frequency ±50 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.19 dB vs. Supply 4.75 V to 5.25 V ±0.02 dB Output 1 dB Compression Point 14.9 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 38.6 dBm Noise Figure 4.0 4.2 dB Rev. B | Page 3 of 13 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OPERATING TO 20 MHz BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
