Datasheet HMC3653LP3BE (Analog Devices) - 6
DescriptionHBT GAIN BLOCK MMIC AMPLIFIER, 7 - 15 GHz
Pages / Page8 / 6 — HMC3653LP3BE. HBT GAIN BLOCK. MMIC AMPLIFIER, 7 - 15 GHz. Pin Descriptions
File Format / SizePDF / 643 Kb
HMC3653LP3BE HBT GAIN BLOCK MMIC AMPLIFIER, 7 - 15 GHz Pin Descriptions
HMC3653LP3BE
v02.0917
pid number function Description interface schematic T 1, 3, 4, 5, no connection necessary. These pins may be connected to nC 6, 7, 9, 11 rf/DC ground. performance will not be affected. m s 2 rfin This pin is AC coupled and matched to 50 ohms. er - 8 rfoUT This pin is AC coupled and matched to 50 ohms. w po r & A 10 Vcc power supply voltage for the amplifier e lin s - plifier 12 Vpd power Control pin for proper control bias m A GnD paddle GnD Ground paddle must be connected to rf/DC ground. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
6
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Second Harmonics vs. Pout Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Temperature @ Pout = 18 dBm Power Dissipation Power Compression @ 10 GHz Psat vs. Vdd P1dB vs. Vdd Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Frequency Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain & Return Loss Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
