Datasheet HMC405 (Analog Devices) - 3
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 10 GHz
Pages / Page6 / 3 — HMC405. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 10 GHz. P1dB vs. …
File Format / SizePDF / 286 Kb
HMC405. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 10 GHz. P1dB vs. Temperature. Psat vs. Temperature. Power Compression @ 1 GHz
HMC405 InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 10 GHz P1dB vs Temperature Psat vs Temperature Power Compression @ 1 GHz
HMC405
v03.0109
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 10 GHz P1dB vs. Temperature Psat vs. Temperature
2 20 20 18 16 16 14 IP 12 12 H 10 +25 C 8 +25 C P1dB (dBm) Psat (dBm) 8 +85 C +85 C -55 C 6 -55 C - C 4 4 S 2 R 0 0 IE 0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 4 5 6 7 8 9 10 FREQUENCY (GHz) FREQUENCY (GHz) IF L P M
Power Compression @ 1 GHz Power Compression @ 7 GHz
22 22 K A 18 18 14 14 OC 10 10 6 6 BL 2 2 IN -2 -2 A Pout Pout Gain Gain Pout (dBm), GAIN (dB), PAE (%) -6 PAE Pout (dBm), GAIN (dB), PAE (%) -6 PAE -10 -10 & G -20 -16 -12 -8 -4 0 4 8 -20 -18 -16 -14 -12 -10 -8 -6 -4 -2 0 2 4 6 INPUT POWER (dBm) INPUT POWER (dBm) R E IV
Gain, Power, Output IP3 & Supply
R
Output IP3 vs. Temperature Current vs. Supply Voltage @ 1 GHz
) D 40 80 34 35 30 30 60 26 25 Ic q (mA) Psat (dBm), IP3 (dBm 20 40 22 IP3 (dBm) 15 +25 C 18 +85 C -55 C 10 20 Gain P1dB 14 5 Psat Icq IP3 0 0 10 0 1 2 3 4 5 6 7 8 9 10 GAIN (dB), P1dB (dBm), 4.5 4.75 5 5.25 5.5 FREQUENCY (GHz) Vs(Vdc) Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 22
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
