Datasheet AD8353 (Analog Devices)
Description | 1 MHz TO 2.7 GHz RF Gain Block |
Pages / Page | 16 / 1 — 1 MHz to 2.7 GHz. RF Gain Block. Data Sheet. AD8353. FEATURES. FUNCTIONAL … |
Revision | F |
File Format / Size | PDF / 347 Kb |
1 MHz to 2.7 GHz. RF Gain Block. Data Sheet. AD8353. FEATURES. FUNCTIONAL BLOCK DIAGRAM
1 MHz to 2.7 GHz RF Gain Block Data Sheet AD8353 FEATURES FUNCTIONAL BLOCK DIAGRAM Fixed gain of 20 dB Operational frequency of 1 MHz to 2.7 GHz BIAS AND VREF VPOS Linear output power up to 9 dBm Input/output internally matched to 50 Ω Temperature and power supply stable RFIN RFOUT Noise figure: 5.3 dB Power supply: 3 V or 5 V COM1 COM2 AD8353 APPLICATIONS
02721-001 Figure 1.
VCO buffers General Tx/Rx amplification Power amplifier predrivers Low power antenna drivers GENERAL DESCRIPTION
The AD8353 is a broadband, fixed-gain, linear amplifier that The noise figure is 5.3 dB at 900 MHz. The reverse isolation operates at frequencies from 1 MHz up to 2.7 GHz. It is (S12) is −36 dB at 900 MHz and −30 dB at 2.7 GHz. intended for use in a wide variety of wireless devices, including cellular, broadband, CATV, and LMDS/MMDS applications. The AD8353 can also operate with a 5 V power supply; in which case, no external inductor is required. Under these By taking advantage of Analog Devices, Inc., high performance, conditions, the AD8353 delivers 8 dBm with 20 dB of gain at complementary Si bipolar process, these gain blocks provide 900 MHz. The dc supply current is 42 mA. At 900 MHz, the excellent stability over process, temperature, and power supply. OIP3 is greater than 22 dBm and is 19 dBm at 2.7 GHz. The noise This amplifier is single-ended and internal y matched to 50 Ω figure is 5.6 dB at 900 MHz. The reverse isolation (S12) is −35 dB. with a return loss of greater than 10 dB over the ful operating frequency range. The AD8353 is fabricated on Analog Devices proprietary, high performance, 25 GHz, Si complementary, bipolar IC process. The AD8353 provides linear output power of 9 dBm with 20 dB The AD8353 is available in a chip scale package that uses an of gain at 900 MHz when biased at 3 V and an external RF exposed paddle for excel ent thermal impedance and low choke is connected between the power supply and the output impedance electrical connection to ground. It operates over a pin. The dc supply current is 42 mA. At 900 MHz, the output −40°C to +85°C temperature range, and an evaluation board is third-order intercept (OIP3) is greater than 23 dBm and is also available. 19 dBm at 2.7 GHz.
Rev. F Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2002–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS APPLICATIONS INFORMATION LOW FREQUENCY APPLICATIONS BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
