Datasheet HMC311LP3 / 311LP3E (Analog Devices)
DescriptionInGaP HBT Gain Block Amplifier SMT, DC - 6 GHz
Pages / Page6 / 1 — HMC311LP3 / 311LP3E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 6 GHz. …
File Format / SizePDF / 955 Kb
HMC311LP3 / 311LP3E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 6 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC311LP3 / 311LP3E Analog Devices
HMC311LP3 / 311LP3E
v06.0617
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 6 GHz Typical Applications Features
The HMC311LP3(E) is ideal for: P1dB Output Power: +15.5 dBm T • Cel ular / PCS / 3G Output IP3: +32 dBm M • Fixed Wireless & WLAN Gain: 14.5 dB • CATV & Cable Modem 50 Ohm I/O’s S - S • Microwave Radio 16 Lead 3x3mm SMT Package: 9mm2 R IE
LIF The HMC311LP3(E) is a GaAs InGaP Heterojunction P Bipolar Transistor (HBT) Gain Block MMIC M SMT DC to 6 GHz amplifiers. This 3x3mm QFN packaged amplifier can be used as either a K A cascadable 50 Ohm gain stage or to drive the LO of C HMC mixers with up to +17 dBm output power. The HMC311LP3(E) offers 14.5 dB of gain and an output LO IP3 of +32 dBm while requiring only 56 mA from a +5V supply. The Darlington feedback pair used results IN B in reduced sensitivity to normal process variations A and yields excel ent gain stability over temperature while requiring a minimal number of external bias components. R & G E IV
Electrical Specifications, Vs= 5V, Rbias= 22 Ohm, T = +25° C A
R D Parameter Min. Typ. Max. Units DC - 1.0 GHz 13.0 14.5 dB Gain 1.0 - 4.0 GHz 12.5 14.3 dB 4.0 - 6.0 GHz 12.0 14.0 dB DC - 2.0 GHz 0.005 0.008 dB/ °C Gain Variation Over Temperature 2.0 - 4.0 GHz 0.008 0.012 dB/ °C 4.0 - 6.0 GHz 0.012 0.016 dB/ °C DC - 1.0 GHz 13 dB Return Loss Input / Output 1.0 - 3.0 GHz 11 dB 3.0 - 6.0 GHz 15 dB Reverse Isolation DC - 6 GHz 18 dB DC - 2.0 GHz 13.5 15.5 dBm Output Power for 1 dB Compression (P1dB) 2.0 - 4.0 GHz 12.0 15.0 dBm 4.0 - 6.0 GHz 10.0 13.0 dBm DC - 1.0 GHz 32 dBm 1.0 - 2.0 GHz 30 dBm Output Third Order Intercept (IP3) 2.0 - 4.0 GHz 28 dBm 4.0 - 6.0 GHz 24 dBm Noise Figure DC - 6 GHz 4.5 dB Supply Current (Icq) 55 74 mA Note: Data taken with broadband bias tee on device output. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
