Datasheet HT16D31A/HT16D31B (Holtek) - 6
ManufacturerHoltek
Description8×9 Constant Current LED Driver
Pages / Page59 / 6 — HT16D31A/HT16D31B. 8×9 Constant Current LED Driver. Pin Description. Pin …
Revision1.10
HT16D31A/HT16D31B. 8×9 Constant Current LED Driver. Pin Description. Pin Name. Type. Function. Approximate Internal Connections
HT16D31A/HT16D31B 8×9 Constant Current LED Driver Pin Description Pin Name Type Function Approximate Internal Connections
HT16D31A/HT16D31B HT16D31A/HT16D31B 8×9 Constant Current LED Driver 8×9 Constant Current LED Driver Pin Description Pin Name Type Function
VDD — Positive power supply for logic circuits VSS — Negative power supply for logic circuits, ground LEDVDD — Positive power supply for driver circuit LEDVSS — Negative power supply for driver circuit, ground CSB/AD I I2C interface device address data set input pin for I2C interface Chip Select pin for SPI 3-wire Interface Serial clock input pin CLK/SCL I Serial Clock (SCL) Input for I2C interface Serial Clock (CLK) Input for SPI 3-wire Interface Serial data input/output pin. Data is input to or comes out from the shift register at the clock DIO/SDA I/O rising edge. I2C interface serial data (SDA) Input/Output – NMOS open-drain output SPI 3-wire serial interface serial data input/output – CMOS output Synchronization clock Input / output pin SYNC I/O If the Master Mode command is programmed, the system clock is output on the SYNC pin. If the Slave Mode command is programmed, the system clock is input on the SYNC pin. CA0~CA8 I/O LED combinations of output pins. (Rows and Commons combo pins)
SCL, SDA (for schmit Trigger type) CSB, CLK (for schmit Trigger type) DIO (for schmit Trigger type) VDD VDD VDD VSS VSS VSS SYNC (for schmit Trigger type) CA0~CA8 LEDVDD VDD Scan Data VSS Rev. 1.10 6 April 11, 2019 Rev. 1.10 7 April 11, 2019 Document Outline Features Applications General Description Selection Table Block Diagram Pin Assignment Pin Description Approximate Internal Connections Absolute Maximum Ratings D.C. Characteristics A.C. Characteristics A.C. Characteristics – SPI 3-wire Serial Bus A.C. Characteristics – IC Serial Bus Timing Diagrams SPI 3-Wire Serial Bus Timing I2C Bus Timing Power on Reset Timing Functional Description Power-on Reset LED Driver System Oscillator Driver Outputs Address Pointer Open/Short Detection Function Over Temperature Protection Constant Current Output Load Supply Voltage – LED_V Display Data RAM – DDRAM Fade Data RAM LED On/Off Control RAM Data CommandDescription Command Table Software Reset RAM Page Address Set Picture Start Page Address Movie Start Page Address Movie Playing Length Set Movie Cycle Time Set Movie Page Delay Time Last Page Set Picture Scrolling Control Display Mode Configuration Mode Fade Function Control Global Fade Time Cascade Mode System Control Constant Current Ratio Brightness Control Mode Control Blanking Control Voltage Setting Read Open Detection Data Read Short Detection Data Read Register Status Read Movie Frame Status Read Movie Loop Status Read Function Flag SPI 3-wire Serial Interface Write Operation Read Operation I2C Serial Interface Data Validity START and STOP Conditions Byte Format Acknowledge Slave Addressing Write Operation Read Operation Power Supply Sequence Operation Flow Charts Application Circuits LED Matrix Circuit RGB LED Matrix Circuit Single LED IC Application Cascade Function Cascade Control Flow Package Information 16-pin NSOP-EP (150mil) Outline Dimensions SAW Type 16-pin QFN (3mm×3mm for FP0.25mm) Outline Dimensions
