CMSH1-20CMSH1-60CMSH1-40CMSH1-100www.centra lsemi.comSURFACE MOUNT SILICONSCHOTTKY RECTIFIERSDESCRIPTION:1.0 AMP, 20 THRU 100 VOLT The CENTRAL SEMICONDUCTOR CMSH1-20 series 1.0 Amp surface mount silicon rectifier is a high quality, well constructed, highly reliable component designed for use in all types of commercial, industrial, entertainment, computer, and automotive applications. MARKING CODE: SEE MARKING CODE TABLE ONFOLLOWING PAGESMB CASEFEATURES: • High reliability • Special selections available MAXIMUM RATINGS: (TA=25°C unless otherwise noted) CMSH1 CMSH1 CMSH1 CMSH1SYMBOL-20-40-60-100UNITS Peak Repetitive Reverse Voltage VRRM 20 40 60 100 V DC Blocking Voltage VR 20 40 60 100 V RMS Reverse Voltage VR(RMS) 14 28 42 70 V Average Forward Current (TA=75°C) IO 1.0 A Peak Forward Surge Current, tp=8.3ms IFSM 30 A Operating and Storage Junction Temperature TJ, Tstg -65 to +150 °C Thermal Resistance ΘJL 20 °C/W ELECTRICAL CHARACTERISTICS: (TA=25°C unless otherwise noted) SYMBOL TESTCONDITIONSTYPMAXUNITS IR VR=Rated VRRM 0.50 mA IR VR=Rated VRRM, TA=125°C 20 mA VF IF=1.0A (CMSH1-20) 0.46 0.55 V VF IF=1.0A (CMSH1-40) 0.48 0.55 V VF IF=1.0A (CMSH1-60) 0.48 0.70 V VF IF=1.0A (CMSH1-100) 0.75 0.85 V CJ VR=4.0V, f=1.0MHz, (CMSH1-20) 68 pF CJ VR=4.0V, f=1.0MHz, (CMSH1-40) 56 pF CJ VR=4.0V, f=1.0MHz, (CMSH1-60) 42 pF CJ VR=4.0V, f=1.0MHz, (CMSH1-100) 45 pF R5 (6-September 2018)
