Datasheet RP516x (Ricoh) - 10
ManufacturerRicoh
Description0.3V Low Output Voltage Low Quiescent Current 100mA Buck DC/DC Converter
Pages / Page30 / 10 — RP516x. TECHNICAL NOTES
RP516x TECHNICAL NOTES
RP516x
No.EA-518-190325
TECHNICAL NOTES
The performance of a power source circuit using this device is highly dependent on the peripheral circuit. A peripheral component or the device mounted on PCB should not exceed a rated voltage, a rated current or a rated power. When designing a peripheral circuit, please be fully aware of the following points. ・When an intermediate voltage other than VIN and GND is input to the CE pin, a supply current may be increased by a through current of a logic circuit in the IC. The CE pin is neither pulled up nor pulled down, therefore the operation is not stable at open. 10
