Datasheet S-35710 (ABLIC) - 6
Manufacturer | ABLIC |
Description | Programmable Wake-up Timer IC |
Pages / Page | 32 / 6 — WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC. S-35710 Series. … |
Revision | 1.0_00 |
File Format / Size | PDF / 795 Kb |
WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC. S-35710 Series. Equivalent Circuits of Pins. Figure 3 SCL. Pin. Figure 4 SDA Pin
WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC S-35710 Series
Rev.1.0_00
SCL SDA
Figure 3 SCL Pin Figure 4 SDA Pin
_______ _______ RST RST _______ _______
Figure 5 RST Pin (S-35710B01I / With Pull-up Resistor) Figure 6 RST Pin (S-35710C01I / Without Pull-up Resistor)
INT INT
Figure 7 INT Pin (S-35710C01I / Nch Open-drain Output) Figure 8 INT Pin (S-35710B01I / CMOS Output)
6
