Datasheet S-1318 (ABLIC) - 10
ManufacturerABLIC
Description5.5 V Input, 100 mA, 95 nA Super Low Current Consumption Voltage Regulator
Pages / Page42 / 10 — 5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE …
Revision1.0_00
File Format / SizePDF / 729 Kb
5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series. *1. *2. *3. *4. *5
5.5 V INPUT, 100 mA, 95 nA SUPER LOW CURRENT CONSUMPTION VOLTAGE REGULATOR S-1318 Series *1 *2 *3 *4 *5
Rev.1.1_00
*1.
VOUT(S): Set output voltage VOUT(E): Actual output voltage The output voltage when VIN = VOUT(S) + 1.0 V, IOUT = 10 mA
*2.
The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current.
*3.
Vdrop = VIN1 − (VOUT3 × 0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 10 mA.
*4.
A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT Δ [ ] mV/°C
*1
= V [ ] ppm/°C
*3
Ta OUT(S) [ ] V
*2
× ÷ 1000 ΔTa•VOUT
*1.
Change in temperature of output voltage
*2.
Set output voltage
*3.
Output voltage temperature coefficient
*5.
Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 10 Document Outline 空白ページ 空白ページ 空白ページ 空白ページ
