VLMU60CL..-280-125 www.vishay.com Vishay Semiconductors UVC Emitting Diode in SMD PackageFEATURES • Ceramic SMT package with quartz lens • Dimension (L x W x H) in mm: 6 x 6 x 1.6 • Forward current: up to 40 mA • Radiant power (typ.): 2.4 mW at 20 mA • Leads / terminations finish: gold plated (Au) • Reflow soldering method • MSL 3 according to J-STD-020 • Material categorization: DESCRIPTION for definitions of compliance please see www.vishay.com/doc?99912 VLMU60CL..-280-125 is a ceramic based standard power UVC LED with quartz lens for long life time. The package APPLICATIONS size is 6 mm x 6 mm x 1.6 mm and the radiant power up to 3.3 mW at 20 mA in a wavelength range of 270 nm • Sterilization to 290 nm. • Medical application • Sensing of gases, germs, DNA, ... PRODUCT GROUP AND PACKAGE DATA • Product group: LED SAFETY ADVICES • Package: SMD ceramic Depending on the mode of operation, these devices emit • Product series: standard power UV LED highly concentrated non visible ultraviolet light which can be hazardous to the human eye. Products which incorporate • Angle of half intensity: ± 62.5° these devices have to follow the safety precautions given in • Lead-finishing: Au IEC 62471 “Photobiological Safety of Lamps and Lamp Systems”. PARTS TABLERADIANT POWERatWAVELENGTHatFORWARD VOLTAGEatPARTCOLOR(mW)I(nm)(V)FIFIFTECHNOLOGY(mA)(mA)(mA)MIN.TYP. MAX.MIN.TYP. MAX.MIN.TYP.MAX. VLMU60CL00-280-125 Ultraviolet 1.4 2.4 3.8 20 270 280 290 20 4.4 6.2 7.5 20 AlGaN ABSOLUTE MAXIMUM RATINGS (Tamb = 25 °C, unless otherwise specified) VLMU60CL..-280-125PARAMETERTEST CONDITIONSYMBOLVALUEUNIT DC forward current IF 40 mA Power dissipation PV 0.3 W Electrostatic discharge HBM: MIL-STD-883 C 3B ESD 2000 V Junction temperature Tj +90 °C Operating temperature range Tamb -30 to +80 °C Storage temperature range Tstg -40 to +100 °C Solder temperature Tsol 260 °C Rev. 1.1, 23-Jan-18 1 Document Number: 84599 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
