Datasheet BL-HRGB39P-TRB (American Bright) - 5
ManufacturerAmerican Bright
DescriptionRGB LED device with built-in IC
Pages / Page8 / 5 — BRIGHT LED ELECTRONICS CORP. Reliability Test. Classification. Test Item. …
File Format / SizePDF / 749 Kb
BRIGHT LED ELECTRONICS CORP. Reliability Test. Classification. Test Item. Reference Standard. Test Conditions. Result
BRIGHT LED ELECTRONICS CORP Reliability Test Classification Test Item Reference Standard Test Conditions Result
BL-HRGB39P-TRB ●
Operation Life MIL-STD-750:1026 IF=20mA MIL-STD-883:1005 Ta=Under room temperature 0/20 JIS-C-7021 :B-1 Test time=1,000hrs High Ta=+65℃±5℃ Temperature MIL-STD-202:103B RH=90%-95% 0/20 High Humidity JIS-C-7021 :B-11 Test time=240hrs Endurance Storage Test High High Ta=+85℃±5℃ MIL-STD-883:1008 Temperature Test time=1,000hrs 0/20 JIS-C-7021 :B-10 Storage Low Low Ta=-35℃±5℃ Temperature JIS-C-7021 :B-12 Test time=1,000hrs 0/20 Storage Temperature MIL-STD-202:107D -35℃ ~ +25℃ ~ +85℃ ~ +25℃ Cycling MIL-STD-750:1051 60min 20min 60min 20min 0/20 MIL-STD-883:1010 Test Time=5cycle JIS-C-7021 :A-4 Thermal Shock MIL-STD-202:107D -35℃±5℃ ~+85℃±5℃ Environmental MIL-STD-750:1051 20min 20min 0/20 Test MIL-STD-883:1011 Test Time=10cycle Solder Preheating: MIL-STD-202:201A Resistance 140℃-160℃,within 2 minutes. MIL-STD-750:2031 0/20 Operation heating: JIS-C-7021 :A-1 260℃(Max.), within 10seconds. (Max.) ●
Judgment criteria of failure for the reliability Measuring items Symbol Measuring conditions Judgment criteria for failure
Luminous intensity Iv ( mcd) IF=20mA Below S1X0.5 Note: 1. U means the upper limit of specified characteristics. S means initial value. 2. After each test, remove test pieces, wait for 2 hours and test pieces have returned to ambient temperature, then take next measurement. Ver1.0 Page: 5 of 8
