Datasheet AP43770 (Diodes)
Manufacturer | Diodes |
Description | High-Performance Usb Pd Controller |
Pages / Page | 9 / 1 — AP43770. HIGH-PERFORMANCE USB PD CONTROLLER. Description. Pin … |
File Format / Size | PDF / 731 Kb |
AP43770. HIGH-PERFORMANCE USB PD CONTROLLER. Description. Pin Assignments. (Top View). TSSOP-16. Features. Applications
AP43770 HIGH-PERFORMANCE USB PD CONTROLLER Description Pin Assignments
The AP43770 is a USB Type-C power delivery controller dedicated to
(Top View)
power source applications with legacy capability. It is compliant with USB Type-C specification release 1.3 and USB power delivery (PD) specification Rev3.0 V1.2. V5V 1 16 VFB_OUT The AP43770 can support PPS APDO with 20mV/step resolution and IFB 2 15 TS 50mA/step current resolution for power management. In addition, it VFB 3 14 ISENP
T
supports Qualcomm Quick Charge 4 for mobile market. What’s more,
C
cable-loss compensation and SOP
command for e-Marker detection AGND 4 13 VIN_PS
U
are embedded too.
D
DP 5 12 PWR_ENB
O
In consideration of customer applications, the AP43770 supports DN 6 11
R
VBUS
P
options for non-PD protocols like BC 1.2, QC4/4+,QC3.0/QC2.0, CC1 7 10 and other legacy protocols with auto-detection. It maintains PGND
W
backwards compatibility with the existing environment. There are rich CC2 8 9
E
V18V power-features embedded on the chip and they can be configured
N
through CC channel.
TSSOP-16 Features Applications
Compliant with USB PD Rev3.0 V1.2
AC Adapters USB-IF PD3.0/PPS Certificated TID = 1090017
Car Chargers Qualcomm QC4 and QC4+,QC3.0, QC2.0 Built-in
USB PD Converter Support VOUT 20mV/Step from 3.3V to 20V
Power Hubs Support Current Limit 50mA/Step up to 6A
Power Banks OTP(One-Time-Programmable ) for Main Firmware MTP (Multi-Time-Programmable ) for System Configuration USB PD Transceiver with High Noise Immunity Built-In CC/CV Controller Support e-Marker Cable Detection Built-In VCONN Switch with OCP Protection Cable Compensation for Different Load Condition Programmable for Configuration through CC Line Support OCP/SCP/OTP/UVP with Auto-Restart Built-In 5V/1.8V LDO Low Standby Current : 550µA Maximum 32V Input Voltage Rating Support Non-USB PD Protocol Options BC 1.2 Legacy Built-In TID(11090017) for USB PD 3.0 PPS Compliance Test Package: TSSOP-16
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Note 3)
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AP43770 1 of 9 April 2019 Document number: DS41284 Rev. 5 - 2
www.diodes.com
© Diodes Incorporated
