Preliminary Datasheet CXT-741Gxx (Cissoid)
ManufacturerCissoid
DescriptionHigh Temperature Automotive Configurable Logic Gates
Pages / Page12 / 1 — The Leader in High Temperature. Semiconductor Solutions. High Temperature …
Revision1.0
File Format / SizePDF / 332 Kb
The Leader in High Temperature. Semiconductor Solutions. High Temperature Automotive Configurable Logic Gates
Preliminary Datasheet CXT-741Gxx Cissoid, Revision: 1.0
The Leader in High Temperature Semiconductor Solutions High Temperature Automotive Configurable Logic Gates Preliminary Datasheet Version: 1.0 (see note 1) General description Features
The CXT-741Gxx are 4 high temperature • Operating junction temperature: from configurable devices enabling 13 different -55°C to +175°C (Tj) logic functions: INV, BUFFER, AND, AND • Supply voltage: 1.65V to 5.5V w/ inverted input, NAND, NAND w/ inverted • Inputs can be driven by 3.3V or 5V input, OR, NOR, NOR w/ inverted input, signals, even for lower supply voltage XOR, NXOR, MUX and D Flip-Flop. • Schmitt trigger inputs for high immunity to slow changing signals These devices are optimized for automotive •  16 mA output drive current applications and specified for operating • CMOS low power consumption junction temperature from -55°C up to • ESD: 2000V HBM or 200V MM +175°C (Tj), in excess of AEC-Q100 • Lead Free Finish & RoHS compliant (Grade 0) qualification standard. • Tiny package: SOT-23 6 leads • AEC-Q100 Grade 0 & PPAP capable2 A/3 A/3 B/1 Y/4 B/1 Y/4 C/6 C/6
CXT-741G57 CXT-741G58
A/3 D/3 Q/4 B/1 Y/4 CLK/1 C/6 CLRB/6
CXT-741G97 CXT-741G175
SOT-23-6 SOT-23-6 B 1 6 C CLK 1 6 CLRB GND 2 5 VDD GND 2 5 VDD A 3 4 Y D 3 4 Q Note 1 Please always refer to the latest datasheet version available at http://www.cissoid.com/files/files/products/galaxy/CXT-741GXX.pdf 2 Contact CISSOID about qualification status
PUBLIC Doc. PDS-192011 V1.0 WWW.CISSOID.COM
1 of 12
