Datasheet ADuM4120/ADuM4120-1 (Analog Devices) - 6
DescriptionIsolated, Precision Gate Driver with 2 A Output
Pages / Page17 / 6 — Data Sheet. ADuM4120/ADuM4120-1. 1.2. RECOMMENDED OPERATING CONDITIONS. …
File Format / SizePDF / 309 Kb
Data Sheet. ADuM4120/ADuM4120-1. 1.2. RECOMMENDED OPERATING CONDITIONS. 1.0. Table 6. Parameter. Value. W ( R. 0.8. WE O. P G. 0.6. IN IT. 0.4. A S
Data Sheet ADuM4120/ADuM4120-1 1.2 RECOMMENDED OPERATING CONDITIONS 1.0 Table 6 Parameter Value W ( R 0.8 WE O P G 0.6 IN IT 0.4 A S
Data Sheet ADuM4120/ADuM4120-1 1.2 RECOMMENDED OPERATING CONDITIONS 1.0 Table 6. ) Parameter Value W ( R 0.8
Operating Temperature Range (TA) −40°C to +125°C
WE O
Supply Voltages
P G 0.6
VDD1 − GND1 or GND2 2.5 V to 6.5 V
IN IT
V 2 4.5 V to 35 V
M
DD2 − VSS2
LI 0.4 FE A S 0.2 0 0 50 100 150 200
002 93-
AMBIENT TEMPERATURE (°C)
54 1 Figure 2. ADuM4120/ADuM4120-1 Thermal Derating Curve, Dependence of Safety-Limiting Values on Case Temperature, per DIN V VDE V 0884-10 Rev. 0 | Page 6 of 17 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS REGULATORY INFORMATION PACKAGE CHARACTERISTICS INSULATION AND SAFETY RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PCB LAYOUT PROPAGATION DELAY RELATED PARAMETERS THERMAL LIMITATIONS AND SWITCH LOAD CHARACTERISTICS UNDERVOLTAGE LOCKOUT (UVLO) OUTPUT LOAD CHARACTERISTICS POWER DISSIPATION DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY INSULATION LIFETIME Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example OUTLINE DIMENSIONS ORDERING GUIDE
