Datasheet ADuM4120/ADuM4120-1 (Analog Devices) - 8
DescriptionIsolated, Precision Gate Driver with 2 A Output
Pages / Page17 / 8 — ADuM4120/ADuM4120-1. Data Sheet. PIN CONFIGURATION AND FUNCTION …
File Format / SizePDF / 309 Kb
ADuM4120/ADuM4120-1. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VDD1 1. 6 V. ADuM4120/. DD2. ADuM4120-1. IN 2. 5 VOUT
ADuM4120/ADuM4120-1 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD1 1 6 V ADuM4120/ DD2 ADuM4120-1 IN 2 5 VOUT
ADuM4120/ADuM4120-1 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD1 1 6 V ADuM4120/ DD2 V ADuM4120-1 IN 2 5 VOUT TOP VIEW
003
GND 3 1 4 GND (Not to Scale) 2
15493- Figure 3. Pin Configuration
Table 10. ADuM4120/ ADuM4120-1 Pin Function Descriptions Pin No. Mnemonic Description
1 VDD1 Supply Voltage for Isolator Side 1. 2 VIN Gate Drive Logic Input. 3 GND1 Ground 1. Ground reference for Isolator Side 1. 4 GND2 Ground 2. Ground reference for Isolator Side 2. 5 VOUT Gate Drive Output. Connect this pin to the gate being driven through an external series resistor. 6 VDD2 Supply Voltage for Isolator Side 2. Rev. 0 | Page 8 of 17 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS REGULATORY INFORMATION PACKAGE CHARACTERISTICS INSULATION AND SAFETY RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PCB LAYOUT PROPAGATION DELAY RELATED PARAMETERS THERMAL LIMITATIONS AND SWITCH LOAD CHARACTERISTICS UNDERVOLTAGE LOCKOUT (UVLO) OUTPUT LOAD CHARACTERISTICS POWER DISSIPATION DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY INSULATION LIFETIME Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example OUTLINE DIMENSIONS ORDERING GUIDE
