Datasheet ADuM4121/ADuM4121-1 (Analog Devices) - 3
DescriptionHigh Voltage, Isolated Gate Driver with Internal Miller Clamp, 2 A Output
Pages / Page16 / 3 — Data Sheet. ADuM4121/ADuM4121-1. SPECIFICATIONS ELECTRICAL …
File Format / SizePDF / 535 Kb
Data Sheet. ADuM4121/ADuM4121-1. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Min. Typ. Max. Unit
Data Sheet ADuM4121/ADuM4121-1 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Min Typ Max Unit
link to page 4 link to page 4 link to page 4
Low-side voltages referenced to GND1. High side voltages referenced to GND2; 2.5 V ≤ VDD1 ≤ 6.5 V; 4.5 V ≤ VDD2 ≤ 35 V, TJ = −40°C to +125°C. Al minimum/maximum specifications apply over the entire recommended operating range, unless otherwise noted. All typical specifications are at TJ = 25°C, VDD1 = 5.0 V, VDD2= 15 V.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
DC SPECIFICATIONS High Side Power Supply VDD2 Input Voltage VDD2 4.5 35 V VDD2 Input Current, Quiescent IDD2(Q) 2.3 2.7 mA Logic Supply VDD1 Input Voltage VDD1 2.5 6.5 V Input Current IDD1 3.6 5 mA VI+ = high, VI− = low Logic Inputs (VI+, VI−) Input Current II+, II− −1 0.01 +1 µA Input Voltage Logic High VIH 0.7 × VDD1 V 2.5 V ≤ VDD1 ≤ 5 V 3.5 V VDD1 > 5 V Logic Low VIL 0.3 × VDD1 V 2.5 V ≤ VDD1 ≤ 5 V 1.5 V VDD1 > 5 V UVLO VDD1 Positive-Going Threshold VVDD1UV+ 2.45 2.5 V Negative-Going Threshold VVDD1UV− 2.3 2.35 V Hysteresis VVDD1UVH 0.1 V VDD2 Grade A Positive Going Threshold VVDD2UV+ 4.4 4.5 V Negative Going Threshold VVDD2UV− 4.1 4.2 V Hysteresis VVDD2UVH 0.2 V Grade B Positive Going Threshold VVDD2UV+ 7.3 7.5 V Negative Going Threshold VVDD2UV− 6.9 7.1 V Hysteresis VVDD2UVH 0.2 V Grade C Positive Going Threshold VVDD2UV+ 11.3 11.6 V Negative Going Threshold VVDD2UV− 10.8 11.1 V Hysteresis VVDD2UVH 0.2 V Thermal Shutdown (TSD) The ADuM4121-1 does not have TSD Positive Edge TTSD_POS 155 °C Hysteresis TTSD_HYST 30 °C Internal NMOS Gate Resistance RDSON_N 0.6 1.6 Ω Tested at 250 mA, VDD2 = 15 V 0.6 1.6 Ω Tested at 1 A, VDD2 = 15 V Internal PMOS Gate Resistance RDSON_P 0.8 1.8 Ω Tested at 250 mA, VDD2 = 15 V 0.8 1.8 Ω Tested at 1 A, VDD2 = 15 V Internal Mil er Clamp Resistance RDSON_MILLER 0.8 2 Ω Tested at 200 mA, VDD2 = 15 V Miller Clamp Voltage Threshold VCLP_TH 1.75 2 2.25 V Referenced to GND2, VDD2 = 15 V Peak Current IPK 2.3 A VDD2 = 12 V, 4 Ω gate resistance SWITCHING SPECIFICATIONS Pulse Width PW 50 ns C 1 1 L = 2 nF, VDD2 = 15 V, RGON = RGOFF = 5 Ω Propagation Delay Rising Edge2 tDLH 22 32 42 ns CL = 2 nF, VDD2 = 15 V, RGON = RGOFF = 5 Ω Falling Edge2 tDHL 30 38 53 ns CL = 2 nF, VDD2 = 15 V, RGON = RGOFF = 5 Ω Rev. 0 | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS REGULATORY INFORMATION PACKAGE CHARACTERISTICS INSULATION AND SAFETY-RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION PRINTED CIRCUIT BOARD (PCB) LAYOUT VI+ and VI− Operation PROPAGATION DELAY-RELATED PARAMETERS UNDERVOLTAGE LOCKOUT (UVLO) OUTPUT LOAD CHARACTERISTICS Miller Clamp POWER DISSIPATION INSULATION LIFETIME TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
