Datasheet ADuM4136 (Analog Devices) - 10
Description | Single-/Dual-Supply, High Voltage Isolated IGBT Gate Driver |
Pages / Page | 16 / 10 — ADuM4136. Data Sheet. 800. 700. SOURCE RESISTANCE. DHL. 600. Y (. DLH. … |
File Format / Size | PDF / 663 Kb |
ADuM4136. Data Sheet. 800. 700. SOURCE RESISTANCE. DHL. 600. Y (. DLH. 500. SINK RESISTANCE. N D. 400. 300. P O R. 200. 100. –40. –20. 120
ADuM4136 Data Sheet 80 800 70 700 t SOURCE RESISTANCE DHL s) 60 n 600 Y ( t A DLH L 50 ) 500 E Ω SINK RESISTANCE N D (m 40 N 400 IO O AT DS G 30 R A 300 P O R 20 P 200 10 100 0 0 –40 –20 0 20 40 60 80 100 120
016
019 75- 75-
AMBIENT TEMPERATURE (°C) TEMPERATURE (°C)
135 135 Figure 16. Propagation Delay vs. Ambient Temperature, Figure 19. Output On Resistance (RDSON) vs. Temperature, VDD2 = 15 V, VDD2 = 5 V, VDD2 − VSS2 = 12 V Tested at 1 A
CH1 = VI+ (5V/DIV) CH1 = V CH2 = V I+ (5V/DIV) 1 GATE (10V/DIV) 1 2 CH3 = FAULT (5V/DIV) 2 CH2 = VGATE (5V/DIV) 3 CH3 = RESET (5V/DIV) 4 3 CH4 = DESAT (5V/DIV)
17 20 0 0
CH1 5V CH2 10V 500ns/DIV A CH1 1.1V CH1 5V CH2 5V 500ns/DIV A CH3 3.3V
75- 75-
CH3 5V CH4 5V 2.5GS/s 400ps/PT CH3 5V 2.5GS/s 400ps/PT
135 135 Figure 17. Example Desaturation Event and Reporting Figure 20. Example RESET to Output Valid
800 10 700 9 SOURCE RESISTANCE 8 600 A) PEAK SINK IOUT ( T 7 N E ) 500 Ω 6 SINK RESISTANCE URR (m PEAK SOURCE IOUT N 400 C 5 O UT DS P R 300 4 UT K O 3 200 A E P 2 100 1 0 0 –40 –20 0 20 40 60 80 100 120
018
12.0 14.5 17.0 19.5 22.0 24.5
021 75- 75-
TEMPERATURE (°C)
135
OUTPUT SUPPLY VOLTAGE (V)
135 Figure 18. Output On Resistance (RDSON) vs. Temperature, VDD2 = 15 V, Figure 21. Peak Output Current vs. Output Supply Voltage, Tested at 250 mA 2.4 Ω Series Resistance (IOUT is the Current Going Into/Out Of the Device Gate) Rev. 0 | Page 10 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performanace Characteristics Applications Information PCB Layout Propagation Delay Related Parameters Protection Features Fault Reporting Desaturation Detection Thermal Shutdown Undervoltage Lockout (UVLO) Faults READY Pin Pin Pin VI+ and VI− Operation Gate Resistance Selection Power Dissipation DC Correctness and Magnetic Field Immunity Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Typical Application Outline Dimensions Ordering Guide
