link to page 14 link to page 14 ADuM3224/ADuM4224Data Sheet)1.8RECOMMENDED OPERATING CONDITIONS(W ER1.6WTable 10.PO1.4ParameterSymbolRatingV DDB Operating Junction TJ −40°C to +125°C 1.2R P Temperature O1.0 Supply Voltages1 V DDA, P 0.8 VDD1 3.0 V to 5.5 V V DD1 VDDA, VDDB 4.5 V to 18 V 0.6G P VDD1 Rise Time tVDD1 1 V/µs TIN A0.4 VDDA, VDDB Rise Time tVDDA, tVDDB 10 V/µs ER0.2 Maximum Input Signal tVIA, tVIB 1 ms OP FE Rise and Fal Times 0SA050100150200 102 Common-Mode Transient, −50 kV/µs to +50 kV/µs AMBIENT TEMPERATURE (°C) 11791- Static2 Figure 2. ADuM3224 Thermal Derating Curve, Dependence of Common-Mode Transient −25 kV/µs to +25 kV/µs Safety-Limiting Values on Case Temperature, per DIN V VDE V 0884-10 Immunity, Dynamic3 1 All voltages are relative to their respective ground. See the Applications ) Information section for information on immunity to external magnetic fields. 2 (W 3.0 Static common-mode transient immunity is defined as the largest dv/dt ER between GND1 and GNDA/GNDB with inputs held either high or low such that W the output voltage remains either above 0.8 × VDDA/VDDB for VIA/VIB = high, or PO 2.5 0.8 V for VIA/VIB = low. Operation with transients above the recommended levels can cause momentary data upsets. V DDB 3 Dynamic common-mode transient immunity is defined as the largest dv/dt 2.0R P between GND1 and GNDA/GNDB with the switching edge coincident with the O transient test pulse. Operation with transients above the recommended levels can cause momentary data upsets. V DDA 1.5, PV DD1 1.0G P TIN A 0.5ER OP FE0SA050100150200 103 AMBIENT TEMPERATURE (°C) 11791- Figure 3. ADuM4224 Thermal Derating Curve, Dependence of Safety-Limiting Values on Case Temperature, per DIN V VDE V 0884-10 Rev. B | Page 8 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V OPERATION ELECTRICAL CHARACTERISTICS—3.3 V OPERATION PACKAGE CHARACTERISTICS INSULATION AND SAFETY RELATED SPECIFICATIONS ADuM3224 Specifications ADuM4224 Specifications REGULATORY INFORMATION DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PRINTED CIRCUIT BOARD LAYOUT UNDERVOLTAGE LOCKOUT PROPAGATION DELAY-RELATED PARAMETERS THERMAL LIMITATIONS AND SWITCH LOAD CHARACTERISTICS OUTPUT LOAD CHARACTERISTICS BOOTSTRAPPED HALF-BRIDGE OPERATION DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION INSULATION LIFETIME OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
