Datasheet ADUM7223 (Analog Devices)
DescriptionIsolated Precision Half-Bridge Driver, 4 A Output
Pages / Page16 / 1 — Isolated Precision Half-Bridge. Driver, 4.0 A Output. Data Sheet. …
RevisionA
File Format / SizePDF / 422 Kb
Isolated Precision Half-Bridge. Driver, 4.0 A Output. Data Sheet. ADuM7223. FEATURES. GENERAL DESCRIPTION
Datasheet ADUM7223 Analog Devices, Revision: A
Isolated Precision Half-Bridge Driver, 4.0 A Output Data Sheet ADuM7223 FEATURES GENERAL DESCRIPTION 4.0 A peak output current
The ADuM7223 is a 4.0 A isolated, half-bridge gate driver that
Working voltage
employs Analog Devices, Inc., iCoupler® technology to provide
High-side or low-side relative to input: 565 V peak
independent and isolated high-side and low-side outputs.
High-side to low-side differential: 700 V peak
Combining high speed CMOS and monolithic transformer
High frequency operation: 1 MHz maximum
technology, these isolation components provide outstanding
Precise timing characteristics
performance characteristics superior to alternatives such as the
64 ns maximum propagation delay
combination of pulse transformers and non-isolated gate
8.5 ns maximum channel-to-channel matching 3.0 V to 5.5 V input voltage
drivers. By integrating the isolator and driver in a single
4.5 V to 18 V output drive
package, propagation delay is a maximum of only 64 ns, and the
UVLO supply at 2.8 V V
propagation skew from channel to channel is a maximum of
DD1 A Version UVLO, V
only 12 ns at 12 V.
DDA and VDDB (VDD2) at 4.1 V B Version UVLO, VDDA and VDDB at 6.9 V
The ADuM7223 provides two independent isolation channels.
C Version UVLO, VDDA and VDDB at 10.5 V
The ADuM7223 operates with an input supply ranging from 3.0 V
CMOS input logic levels
to 5.5 V, providing compatibility with lower voltage systems.
High common-mode transient immunity: >25 kV/μs
The outputs operate in a wide range from 4.5 V to 18 V with
High junction temperature operation: 125°C
three output voltage versions available. The 5 mm × 5 mm, LGA
Default low output 5 mm × 5 mm, 13-terminal LGA
package provides 565 V operating voltage from input to output and 700 V from output to output.
In comparison to gate drivers employing high voltage level
Switching power supplies
translation methodologies, this gate driver offers the benefit of
Isolated IGBT/MOSFET gate drives
true, galvanic isolation between the input and each output. As a
Industrial inverters
result, this gate driver provides reliable control over the switching characteristics of IGBT/MOSFET configurations over a wide range of positive or negative switching voltages.
FUNCTIONAL BLOCK DIAGRAM ADuM7223 GND1 1 13 VDDA V 2 ENCODE DECODE 12 V IA OA V 3 11 IB GNDA NC 4 DISABLE 5 10 VDDB NC 6 ENCODE DECODE 9 VOB VDD1 7 8 GNDB
001
NC = NO CONNECT
740- 1 1 Figure 1.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013–2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety-Related Specifications Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Applications Information Printed Circuit Board (PCB) Layout Propagation Delay-Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimension Ordering Guide
