Datasheet ADuM3220/ADuM3221 (Analog Devices)
DescriptionIsolated 4 A Dual-Channel Gate Driver
Pages / Page16 / 1 — Isolated, 4 A Dual-Channel Gate Driver. Data Sheet. ADuM3220/. ADuM3221. …
RevisionC
File Format / SizePDF / 622 Kb
Isolated, 4 A Dual-Channel Gate Driver. Data Sheet. ADuM3220/. ADuM3221. FEATURES. GENERAL DESCRIPTION. 4 A peak output current
Datasheet ADuM3220/ADuM3221 Analog Devices, Revision: C
link to page 1
Isolated, 4 A Dual-Channel Gate Driver Data Sheet ADuM3220/ ADuM3221 FEATURES GENERAL DESCRIPTION 4 A peak output current
The ADuM3220/ADuM32211 are isolated, 4 A dual-channel gate
Precise timing characteristics
drivers based on the Analog Devices, Inc., iCoupler® technology.
60 ns maximum isolator and driver propagation delay
Combining high speed CMOS and monolithic transformer technol-
5 ns maximum channel-to-channel matching
ogy, these isolation components provide outstanding performance
High junction temperature operation: 125°C
characteristics superior to the alternatives, such as the combination
3.3 V to 5 V input logic
of pulse transformers and gate drivers.
4.5 V to 18 V output drive
The ADuM3220/ADuM3221 provide digital isolation in two
UVLO at 2.5 V VDD1
independent isolation channels. They have a maximum propagation
ADuM3220A/ ADuM3221A U VLO at 4.1 V VDD2
delay of 60 ns and 5 ns channel-to-channel matching. In comparison
ADuM3220B/ ADuM3221B UV LO at 7.0 V VDD2
to gate drivers that employ high voltage level translation method-
Thermal shutdown protection at >150°C
ologies, the ADuM3220/ADuM3221 offer the benefit of true,
Output shoot-through logic protection on the ADuM3220
galvanic isolation between the input and each output, enabling
Default low output
voltage translation across the isolation barrier. The ADuM3220
High frequency operation: dc to 1 MHz
has shoot-through protection logic, which prevents both outputs
CMOS input logic levels
from being on at the same time, whereas the ADuM3221 allows
High common-mode transient immunity: >25 kV/μs
both outputs to be on at the same time. Both parts offer a default
Enhanced system-level ESD performance per IEC 61000-4-x
output low characteristic as required for gate drive applications.
Safety and regulatory approvals UL recognition
The ADuM3220/ADuM3221 operate with an input supply voltage
2500 V rms for 1 minute per UL 1577
ranging from 3.0 V to 5.5 V, providing compatibility with lower
CSA Component Acceptance Notice #5A
voltage systems. The outputs of the ADuM3220A/ADuM3221A
VDE certificate of conformity
can be operated at supply voltages from 4.5 V to 18 V. The outputs
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12
of the ADuM3220B/ADuM3221B can be operated at supply
VIORM = 560 V peak
voltages from 7.6 V to 18 V.
Small footprint and low profile
The junction temperature of the ADuM3220/ADuM3221 is
Narrow body, RoHS-compliant, 8-lead SOIC
specified from −40°C to +125°C.
5 mm × 6 mm × 1.6 mm Qualified for automotive applications APPLICATIONS Isolated synchronous dc-to-dc converters MOSFET/IGBT gate drivers FUNCTIONAL BLOCK DIAGRAMS ADuM3220 ADuM3221 VDD1 1 8 VDD2 VDD1 1 8 VDD2 DECODE DECODE AND V 2 ENCODE AND V 2 ENCODE IA 7 7 LEVEL VOA IA LEVEL VOA SHIFT SHIFT DECODE DECODE AND V 3 ENCODE AND IB 6 V V 3 ENCODE 6 V LEVEL OB IB LEVEL OB SHIFT SHIFT GND
1 2
1 4 5 GND2 5
00
GND1 4 GND2
10 4- 4- 99 99 08 08 Figure 1. Figure 2. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 7,075,239.
Rev. C Document Feedback Information furnished by Analog Devices is be lieved to be accurate and reliable. However, no responsibility is assumed by Analog Devices fo r its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2010–2012 Analog Devices, Inc. Al l rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagrams Table of Contents Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information PC Board Layout Propagation Delay-Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
