Datasheet ADuM3221-EP (Analog Devices)
Description | Isolated 4 A Dual-Channel Gate Driver |
Pages / Page | 12 / 1 — Isolated, 4 A Dual-Channel Gate Driver. Enhanced Product. ADuM3221-EP. … |
File Format / Size | PDF / 693 Kb |
Isolated, 4 A Dual-Channel Gate Driver. Enhanced Product. ADuM3221-EP. FEATURES. APPLICATIONS. 4 A peak output current
Isolated, 4 A Dual-Channel Gate Driver Enhanced Product ADuM3221-EP FEATURES APPLICATIONS 4 A peak output current Isolated synchronous dc-to-dc converters Precise timing characteristics MOSFET/IGBT gate drivers 60 ns maximum isolator and driver propagation delay GENERAL DESCRIPTION 5 ns maximum channel to channel matching High junction temperature operation: 125°C
The ADuM3221-EP1 is an isolated, 4 A dual-channel gate driver
3.3 V to 5 V input logic
based on the Analog Devices, Inc., iCoupler® technology.
7.6 V to 18 V output drive
Combining high speed CMOS and monolithic transformer
Undervoltage lockout (UVLO) at 7.0 V V
technology, this isolation component provides outstanding
DD2 Thermal shutdown protection at >150°C
performance characteristics superior to the alternatives, such as the
Default low output
combination of pulse transformers and gate drivers.
High frequency operation: dc to 1 MHz
The ADuM3221-EP provides digital isolation in two independent
CMOS input logic levels
isolation channels. It has a maximum propagation delay of 60 ns
High common-mode transient immunity: 25 kV/µs
and 5 ns channel to channel matching. In comparison to gate
Safety and regulatory approvals
drivers that employ high voltage level translation methodologies,
UL recognition
the ADuM3221-EP offers the benefit of true, galvanic isolation
2500 V rms for 1 minute per UL 1577
between the input and each output, enabling voltage translation
CSA Component Acceptance Notice 5A (pending)
across the isolation barrier. The ADuM3221-EP allows both
VDE certificate of conformity (pending)
outputs to be on at the same time. This device offers a default
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12
output low characteristic as required for gate drive applications.
VIORM = 560 V peak Small footprint and low profile
The ADuM3221-EP operates with an input supply voltage ranging
Narrow-body, RoHS compliant, 8-lead SOIC
from 3.0 V to 5.5 V, providing compatibility with lower voltage
4.9 mm × 6 mm × 1.55 mm
systems. The outputs of the ADuM3221-EP can be operated at supply voltages from 7.6 V to 18 V.
ENHANCED PRODUCT FEATURES
The junction temperature of the ADuM3221-EP is specified
Supports defense and aerospace applications (AQEC standard)
from −55°C to +125°C.
Military temperature range: −55°C to +125°C Controlled manufacturing baseline
Additional application and technical information can be found
1 assembly/test site
in the ADuM3221 data sheet.
1 fabrication site Enhanced product change notification Qualification data available on request FUNCTIONAL BLOCK DIAGRAM ADuM3221-EP VDD1 1 8 VDD2 DECODE V 2 ENCODE AND IA 7 LEVEL VOA SHIFT DECODE V 3 ENCODE AND IB 6 V LEVEL OB SHIFT GND1 4 5 GND2
102 14765- Figure 1. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 7,075,239.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V OPERATION ELECTRICAL CHARACTERISTICS—3.3 V OPERATION PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
