Datasheet ADUM6132 (Analog Devices) - 8
DescriptionIsolated Half-Bridge Driver with Integrated Isolated High-Side Supply
Pages / Page16 / 8 — ADuM6132. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 16.0. 1.2. …
File Format / SizePDF / 318 Kb
ADuM6132. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 16.0. 1.2. 15.5. 1.0. DD = 5.0V. 15.0. 0.8. VDD = 4.5V. TION. DD = 5.5V. (V). 14.5. 0.6. ISO
ADuM6132 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 16.0 1.2 15.5 1.0 DD = 5.0V 15.0 0.8 VDD = 4.5V TION DD = 5.5V (V) 14.5 0.6 ISO
All typical performance curves are based on operation at TA = 25°C, unless otherwise noted.
16.0 1.2 V 15.5 1.0 DD = 5.0V ) (W 15.0 0.8 VDD = 4.5V V TION DD = 5.5V V A DD = 5.5V (V) IP 14.5 S 0.6 ISO IS V D VDD = 4.5V R 14.0 0.4 OWE VDD = 5.0V P 13.5 0.2 13.0 0 0 5 10 15 20 25
024
0 5 10 15 20 25
027
I
07393-
ISO LOAD CURRENT (mA) I
07393-
Figure 4. Typical VISO Supply Voltage vs. IISO External Load Figure 7. Typical Total Power Dissipation vs. IISO External Load
300 14.8 V 14.6 DD = 4.5V VDD = 5.5V 250 VDD = 5.0V 14.4 ) 14.2 V mA) V DD = 5.0V ( 200 14.0 NT AD ( O V 13.8 DD = 5.5V 150 CURRE 13.6 22mA L UT AT 13.4 NP 100 I VDD = 4.5V ISOV 13.2 I DD 50 13.0 12.8 0 12.6 0 5 10 15 20 25
025
–40 –20
028
0 20 40 60 80 100 120 I
07393-
ISO LOAD CURRENT (mA) AMBIENT TEMPERATURE (°C)
07393- Figure 5. Typical IDD Supply Current vs. IISO External Load Figure 8. Typical VISO Output Voltage at Maximum Combined Load over Temperature
30 2500 VDD = 5.5V 25 2000 V ) DD = 4.5V W VDD = 4.5V 20 (m %) N ( IO 1500 T V V DD = 5.0V DD = 5.0V NCY PA E 15 ICI ISSI F D 1000 F E 10 ER VDD = 5.5V W PO 500 5 0 0 0 5 10 15 20 25
026
1 10 100 1000
029
I
07393-
ISO LOAD CURRENT (mA) V
07393-
ISO LOAD IMPEDANCE (Ω)
Figure 6. Typical VISO Supply Efficiency vs. IISO External Load Figure 9. Power Dissipation vs. Load Impedance for Fault Conditions Rev. B | Page 8 of 16 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operation Conditions Absolute Maximum Values ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Applications Information Typical Application Usage PCB Layout Thermal Analysis Undervoltage Lockout Propagation Delay-Related Parameters Magnetic Field Immunity Insulation Lifetime Outline Dimensions Ordering Guide
