Datasheet ADUM1234 (Analog Devices) - 6
DescriptionIsolated, Precision Half-Bridge Driver, 0.1 A Output
Pages / Page12 / 6 — ADuM1234. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. …
File Format / SizePDF / 262 Kb
ADuM1234. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. Rating. ESD CAUTION. Table 8. Maximum Continuous Working Voltage1
ADuM1234 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating ESD CAUTION Table 8 Maximum Continuous Working Voltage1
link to page 10 link to page 6 link to page 6 link to page 6 link to page 6
Ambient temperature = 25°C, unless otherwise noted. Stresses above those listed under Absolute Maximum Ratings
Table 7.
may cause permanent damage to the device. This is a stress
Parameter Rating
rating only; functional operation of the device at these or any other conditions above those indicated in the operational Storage Temperature (TST) −55°C to +150°C section of this specification is not implied. Exposure to absolute Ambient Operating Temperature (TA) −40°C to +105°C maximum rating conditions for extended periods may affect Input Supply Voltage1 (VDD1) −0.5 V to +7.0 V device reliability. Output Supply Voltage1 (VDDA, VDDB) −0.5 V to +27 V Input Voltage1 (VIA, VIB) −0.5 V to VDD1 + 0.5 V Output Voltage1
ESD CAUTION
VOA −0.5 V to VDDA + 0.5 V VOB −0.5 V to VDDB + 0.5 V Input-to-Output Voltage2 −700 V peak to +700 V peak Output Differential Voltage3 700 V peak Output DC Current (IOA, IOB) −20 mA to +20 mA Common-Mode Transients4 −100 kV/µs to +100 kV/µs 1 All voltages are relative to their respective grounds. 2 Input-to-output voltage is defined as GNDA − GND1 or GNDB − GND1. 3 Output differential voltage is defined as GNDA − GNDB. 4 Refers to common-mode transients across any insulation barrier. Common- mode transients exceeding the absolute maximum ratings may cause latch-up or permanent damage.
Table 8. Maximum Continuous Working Voltage1 Parameter Max Unit Constraint
AC Voltage, Bipolar Waveform 560 V peak 50-year minimum lifetime AC Voltage, Unipolar Waveform Basic Insulation 700 V peak Analog Devices recommended maximum working voltage DC Voltage Basic Insulation 700 V peak Analog Devices recommended maximum working voltage 1 Refers to continuous voltage magnitude imposed across the isolation barrier. See the Insulation Lifetime section for more information. Rev. A | Page 6 of 12 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Perfomance Characteristics Applications Information Common-Mode Transient Immunity Insulation Lifetime Outline Dimensions Ordering Guide
