Datasheet LZ1-00NW05 (LedEngin) - 3
ManufacturerLedEngin
DescriptionHigh Luminous Efficacy 5W Neutral White LED
Pages / Page13 / 3 — Minimum. Maximum. Typical. Bin. Luminous Flux. Code. @ I. F = 1000mA. @ …
File Format / SizePDF / 280 Kb
Minimum. Maximum. Typical. Bin. Luminous Flux. Code. @ I. F = 1000mA. @ IF = 1000mA. @ IF = 1500mA. (lm). Forward Voltage (V. (V). Led
Minimum Maximum Typical Bin Luminous Flux Code @ I F = 1000mA @ IF = 1000mA @ IF = 1500mA (lm) Forward Voltage (V (V) Led
Product Nomenclature The LZ Series part number designation is defined as follows: L Z A – B C D E F G - H J K L Base Part Number Bin Code Where: A – designates the number of LED die in the package (“1” for 5W) B – designates the package level (“0” for Emitter) C – designates the radiation pattern (“0” for Lambertian) D and E – designate the color (“NW” for Neutral White: 3800 K < CCT < 4750 K) F and G – designate the Power (“05” for 5W typical rating) H – designates the Luminous Flux bin (See Table 1) J and K – designate the CCT bin groups (see Figure 1 and Table 3) L – designates the VF bin (See Table 2) Luminous Flux Bins Table 1:
Luminous Flux
Luminous Flux
(Φ V) V) V)
Code @ I
[1,2] [1,2] [2]
F = 1000mA @ IF = 1000mA @ IF = 1500mA (lm) (lm) (lm)
N 146 182 215 P 182 228 260 Q 228 285 320 Notes for Table 1: 1. Luminous flux performance guaranteed within published operating conditions. LedEngin maintains a tolerance of ± 10% on flux measurements. 2. Future products will have even higher levels of luminous flux performance. Contact LedEngin Sales for updated information. Forward Voltage Bins Table 2:
Minimum Maximum Bin Forward Voltage (V Forward Voltage (V F) F) Code @ I
[1] [1]
F = 1000mA @ IF = 1000mA (V) (V)
F 3.20 3.44 G 3.44 3.68 H 3.68 3.92 J 3.92 4.16 K 4.16 4.40 Notes for Table 2: 1. LedEngin maintains a tolerance of ± 0.04V for forward voltage measurements.
Led
Engin, Inc. 3 LZ1-00NW05 (01/11/10)
