Datasheet MAX1618 (Maxim) - 5
Manufacturer | Maxim |
Description | Remote Temperature Sensor with SMBus Serial Interface |
Pages / Page | 18 / 5 — Remote Temperature Sensor. with SMBus Serial Interface. MAX1618 |
Revision | 1 |
File Format / Size | PDF / 254 Kb |
Remote Temperature Sensor with SMBus Serial Interface MAX1618 ____________________________Typical Operating Characteristics (continued)
(TA = +25°C, unless otherwise noted.)
TEMPERATURE ERROR vs. TEMPERATURE ERROR COMMON-MODE NOISE FREQUENCY vs. DXP-DXN CAPACITANCE
120 0 AC-COUPLED TO DXN VCC = 5V 2200pF DXN-DXP CAPACITOR 100 MAX1618 toc04 MAX1618 toc05 °C) VIN = 100mVp-p °C) 80 60 -10 40 TEMPERATURE ERROR ( V TEMPERATURE ERROR ( IN = 50mVp-p 20 0 -20 10 100 1000 0 20 40 60 80 100 COMMON-MODE NOISE FREQUENCY (MHz) DXP-DXN CAPACITANCE (nF)
STANDBY SUPPLY CURRENT vs. CLOCK FREQUENCY
50 µA) 40 MAX1618 toc06 30 VCC = 5V 20 VCC = 3.3V STANDBY SUPPLY CURRENT ( 10 0 1 10 100 1000 CLOCK FREQUENCY (kHz)
STANDBY SUPPLY CURRENT vs. SUPPLY VOLTAGE RESPONSE TO THERMAL SHOCK
100 120 90 110 µA) 80 MAX1618 toc07 100 MAX1618 toc08 70 ADD0, ADD1 = GND 90 °C) 60 80 50 70 40 60 TEMPERATURE ( 30 50 ADD0, ADD1 = HIGH-Z STANDBY SUPPLY CURRENT ( 20 40 10-PIN µMAX IMMERSED IN 10 30 +115°C FLUORINERT BATH 0 20 0 1 2 3 4 5 -2 0 2 4 6 8 10 12 14 16 18 20 SUPPLY VOLTAGE (V) TIME (sec)
_______________________________________________________________________________________ 5
