Datasheet MAX1661, MAX1662, MAX1663 (Maxim) - 4
Manufacturer | Maxim |
Description | Serial to Parallel Parallel to Serial Converters and Load Switch Controllers with SMBus Interface |
Pages / Page | 16 / 4 — Serial-to-Parallel/Parallel-to-Serial Converters and Load-Switch … |
File Format / Size | PDF / 152 Kb |
Serial-to-Parallel/Parallel-to-Serial Converters and Load-Switch Controllers with SMBus Interface
Serial-to-Parallel/Parallel-to-Serial Converters and Load-Switch Controllers with SMBus Interface __________________________________________Typical Operating Characteristics
(VCC = +5.0V, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT I/O_ SINK CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. SUPPLY VOLTAGE vs. SUPPLY VOLTAGE
4.5 5.0 15.0 4.5 4.0 13.5 VCC = 5.5V VI/O_ = 1.0V MAX1661toc02 4.0 MAX1661toc03 12.0 MAX1661toc01 3.5 µA) 3.5 µA) 10.5 3.0 3.0 9.0 2.5 VCC = 2.7V 2.5 7.5 2.0 V 2.0 6.0 I/O_ = 0.4V 1.5 SINK CURRENT (mA) SUPPLY CURRENT ( 1.5 SUPPLY CURRENT ( 4.5 1.0 1.0 3.0 0.5 0.5 1.5 ALL I/Os OFF 0 0 0 -40 -20 0 20 40 60 80 100 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 0.6 1.2 1.8 2.4 3.0 3.6 4.2 4.8 5.4 6.0 TEMPERATURE (°C) SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V)
I/O_ CURRENT LIMIT vs. TEMPERATURE I/O_ CURRENT LIMIT vs. I/O_ VOLTAGE POR DELAY vs. TEMPERATURE
26 25.0 40 VI/O_ FORCED TO 15V 22.5 24 VCC = 5.5V 35 MAX1661toc04 20.0 MAX1661toc05 VCC = 5.5V MAX1661toc06 22 30 17.5 20 µs) 25
MAX1661/MAX1662/MAX1663
15.0 VCC = 2.7V 18 12.5 20 10.0 16 POR DELAY ( 15 CURRENT LIMIT (mA) CURRENT LIMIT (mA) 7.5 14 10 5.0 12 2.5 5 10 0 0 -40 -20 0 20 40 60 80 100 0 3 6 9 12 15 18 21 24 27 30 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) VI/O_ (V) TEMPERATURE (°C)
I/O_ INPUT BIAS CURRENT I/O_INPUT BIAS CURRENT POR DELAY vs. SUPPLY VOLTAGE vs. TEMPERATURE vs. OUTPUT VOLTAGE
35 1.0 1.0 VCC = 5.5V 0.9 V 0.9 30 I/O_ = 15V MAX1661toc07 0.8 MAX1661toc08 0.8 MAX1661toc09 µA) 25 µA) 0.7 0.7 µs) 0.6 0.6 20 0.5 0.5 15 0.4 0.4 POR DELAY ( 10 0.3 0.3 INPUT BIAS CURRENT ( INPUT BIAS CURRENT ( 0.2 0.2 5 0.1 0.1 0 0 0 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 0 3 6 9 12 15 18 21 24 27 30 SUPPLY VOLTAGE (V) TEMPERATURE (°C) OUTPUT VOLTAGE (V) ? ?W2@@@@@@@@@h?W2@@@@@@@@@ ?W2@@@@@@@f@@@@@@@@@6X?g?W2@@@@@@@@@f@@@@@@@@ ?W2@@@@@@@@@h?W2@@@@@@@@@?
4 _______________________________________________________________________________________
W&@@@@@@@@@@hW&@@@@@@@@@@ W&@@@@@@@@f3@@@@@@@@@)XgW&@@@@@@@@@5f@@@@@@@@ W&@@@@@@@@@@hW&@@@@@@@@@@? ?W&@@@@@@@@@@@g?W&@@@@@@@@@@@ ?W&@@@@@@@@@fV'@@@@@@@@@)X?e?W&@@@@@@@@@(Yf@@@@@@@@ ?W&@@@@@@@@@@@g?W&@@@@@@@@@@@? W&@@@@@@@@@@@@gW&@@@@@@@@@@@@ W&@@@@@@@@@@f?V'@@@@@@@@@)XeW&@@@@@@@@@(Y?f@@@@@@@@ W&@@@@@@@@@@@@gW&@@@@@@@@@@@@? ?W&@@@@@@@@@@@@@f?W&@@@@@@@@@@@@@ ?W&@@@@@@@@@@@gV'@@@@@@@@@)KO&@@@@@@@@@(Yg@@@@@@@@ ?W&@@@@@@@@@@@@@f?W&@@@@@@@@@@@@@? W&@@@@@@@@@@@@@@fW&@@@@@@@@@@@@@@ W&@@@@@@@@@@@@g?V'@@@@@@@@@@@@@@@@@@@@(Y?g@@@@@@@@ ?7@@@@@@@@@@@@@@fW&@@@@@@@@@@@@@@? ?W&@@@@@@@@@@@@@@@e?W&@@@@@@@@@@@@@@@ ?W&@@@@@@@@@@@@@hV'@@@@@@@@@@@@@@@@@@(Yh@@@@@@@@ J@@@@@@@@@@@@@@@e?W&@@@@@@@@@@@@@@@? W&@@@@@@@@@@@@@@@@eW&@@@@@@@@@@@@@@@@ W&@@@@@@@@@@@@@@h?V'@@@@@@@@@@@@@@@@(Y?h@@@@@@@@ ?W&@@@@@@@@@@@@@@@eW&@@@@@@@@@@@@@@@@? ?W&@@@@@@@@@@@@@@@@@?W&@@@@@@@@@@@@@@@@@ ?O&@@@@@@@@@@@@@@@heV'@@@@@@@@@@@@@@(Yhe@@@@@@@@ W&@@@@@@@@@@@@@@@@?W&@@@@@@@@@@@@@@@@@? W&@@@@@@@@@@@@@@@@@@W&@@@@@@@@@@@@@@@@@@hf?W2@@@@@@@@@@@@@@@@@he?N@@@@@@@@@@@@@(Y?he@@@@@@@@hf?W&@@@@@@@@@@@@@@@@@W&@@@@@@@@@@@@@@@@@@? ?W&@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@hfW&@@@@@@@@@@@@@@@@@@hf3@@@@@@@@@@@@Hhf@@@@@@@@hfW&@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@? W&@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@he?W&@@@@@@@@@@@@@@@@@@@hf?@@@@@@@@@@@@Lhf@@@@@@@@he?W&@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@? ?W&@@@@@@@@@@@(Y@@@@@@@@@@@@@@@@@@(Y@@@@@@@@heW&@@@@@@@@@@(M?@@@@@@@he?W&@@@@@@@@@@@@)X?he@@@@@@@@heW&@@@@@@@@@@(Y@@@@@@@@@@@@@@@@@@(Y@@@@@@@@? W&@@@@@@@@@@@(Y?@@@@@@@@@@@@@@@@@(Y?@@@@@@@@h?W&@@@@@@@@@@(Y??@@@@@@@heW&@@@@@@@@@@@@@@)Xhe@@@@@@@@h?W&@@@@@@@@@@(Y?@@@@@@@@@@@@@@@@@(Y?@@@@@@@@? ?W&@@@@@@@@@@@(Ye@@@@@@@@@@@@@@@@(Ye@@@@@@@@hW&@@@@@@@@@@(Ye?@@@@@@@h?W&@@@@@@@@@@@@@@@@)X?h@@@@@@@@hW&@@@@@@@@@@(Ye@@@@@@@@@@@@@@@@(Ye@@@@@@@@? W&@@@@@@@@@@@(Y?e@@@@@@@@@@@@@@@(Y?e@@@@@@@@g?W&@@@@@@@@@@(Y?eJ@@@@@@@hW&@@@@@@@@@@@@@@@@@@)Xh@@@@@@@@g?W&@@@@@@@@@@(Y?e@@@@@@@@@@@@@@@(Y?e@@@@@@@@? ?W&@@@@@@@@@@@(Yf@@@@@@@@@@@@@@(Yf@@@@@@@@gW&@@@@@@@@@@(Ye?W&@@@@@@@g?O&@@@@@@@@@@@@@@@@@@@@)X?g@@@@@@@@gW&@@@@@@@@@@(Yf@@@@@@@@@@@@@@(Yf@@@@@@@@? W&@@@@@@@@@@@(Y?f@@@@@@@@@@@@@(Y?f@@@@@@@@f?W&@@@@@@@@@@(Y?eW&@@@@@@@@f?W2@@@@@@@@@@@@@@@@@@@@@@@)Xg@@@@@@@@f?W&@@@@@@@@@@(Y?f@@@@@@@@@@@@@(Y?f@@@@@@@@? ?W&@@@@@@@@@@@(Yg@@@@@@@@@@@@(Yg@@@@@@@@fW&@@@@@@@@@@(Ye?W&@@@@@@@@@fW&@@@@@@@@@@@0MI'@@@@@@@@@@)K?f@@@@@@@@fW&@@@@@@@@@@(Yg@@@@@@@@@@@@(Yg@@@@@@@@? W&@@@@@@@@@@@(Y?g@@@@@@@@@@@(Y?g@@@@@@@@e?W&@@@@@@@@@@(Y?e?7@@@@@@@@@@e?W&@@@@@@@@@@(M?eV'@@@@@@@@@@@6X?e@@@@@@@@e?W&@@@@@@@@@@(Y?g@@@@@@@@@@@(Y?g@@@@@@@@? ?W&@@@@@@@@@@@(Yh@@@@@@@@@@(Yh@@@@@@@@eW&@@@@@@@@@@(YfJ@@@@@@@@@@@eW&@@@@@@@@@@(Yf?V'@@@@@@@@@@@)Xe@@@@@@@@eW&@@@@@@@@@@(Yh@@@@@@@@@@(Yh@@@@@@@@? ?7@@@@@@@@@@@(Y?h@@@@@@@@@(Y?h@@@@@@@@?W&@@@@@@@@@@(Y?e?W&@@@@@@@@@@@e7@@@@@@@@@@(Y?gV'@@@@@@@@@@@1e@@@@@@@@?W&@@@@@@@@@@(Y?h@@@@@@@@@(Y?h@@@@@@@@? ?@@@@@@@@@@@0Yhe@@@@@@@@0Yhe@@@@@@@@?&@@@@@@@@@@0Yf?&@@@@@@@@@@@@e@@@@@@@@@@0Yh?V4@@@@@@@@@@@e@@@@@@@@?&@@@@@@@@@@0Yhe@@@@@@@@0Yhe@@@@@@@@? ?
