Datasheet FMMT619 (Diodes) - 4
Manufacturer | Diodes |
Description | NPN |
Pages / Page | 7 / 4 — A Product Line of. Diodes Incorporated. FMMT619. Electrical … |
File Format / Size | PDF / 228 Kb |
A Product Line of. Diodes Incorporated. FMMT619. Electrical Characteristics. Characteristic Symbol. Min. Typ. Max. Unit. Test. Condition
A Product Line of Diodes Incorporated FMMT619 Electrical Characteristics
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Min Typ Max Unit Test Condition OFF CHARACTERISTICS
Collector-Base Breakdown Voltage BVCBO 50 190 - V IC = 100µA Collector-Emitter Breakdown Voltage (Note 9) BVCEO 50 65 - V IC = 10mA Emitter-Base Breakdown Voltage BVEBO 7 8.3 - V IE = 100µA Collector Cut-off Current ICBO - - 100 nA VCB = 40V Emitter Cut-off Current IEBO - - 100 nA VEB = 6V Collector Emitter Cut-off Current ICES - - 100 nA VCES = 40V
ON CHARACTERISTICS (Note 9)
200 400 - IC = 10mA, VCE = 2V 300 450 - IC = 200mA, VCE = 2V Static Forward Current Transfer Ratio hFE 200 400 - - IC = 1A, VCE = 2V 100 225 - IC = 2A, VCE = 2V - 40 - IC = 6A, VCE = 2V - 10 20 IC = 0.1A, IB = 10mA Collector-Emitter Saturation Voltage VCE(sat) - 125 200 mV IC = 1A, IB = 10mA - 150 220 IC = 2A, IB = 50mA Base-Emitter Saturation Voltage VBE(sat) - 0.87 1.0 V IC = 2A, IB = 50mA Base-Emitter Saturation Voltage VBE(on) - 0.82 1.0 V IC = 2A, VCE = 2V
SMALL SIGNAL CHARACTERISTICS
Transition Frequency fT 100 165 - MHz IC = 50mA, VCE = 10V, f = 100MHz Collector Output Capacitance Cobo - 12 20 pF VCB = 10V, f = 1MHz Turn-On Time t(on) - 170 - ns VCC = 10V, IC = 1A, Turn-Off Time t(off) - 750 - IB1 ns = -IB2 = 10mA Notes: 9. Measured under pulsed conditions. Pulse width ≤ 300µs. Duty cycle ≤ 2% FMMT619 4 of 7 October 2012 Document number: DS33236 Rev. 8 - 2
www.diodes.com
© Diodes Incorporated
