Datasheet PI4GTL2002 (Diodes) - 3
Manufacturer | Diodes |
Description | 2-CHANNEL Gtl Level Shifter & Transceiver |
Pages / Page | 13 / 3 — PI4GTL2002. Maximum Ratings. Note:. Recommended Operation Conditions. … |
File Format / Size | PDF / 1.4 Mb |
PI4GTL2002. Maximum Ratings. Note:. Recommended Operation Conditions. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit. www.diodes.com
PI4GTL2002
GREF DREF SREF Input Sn Output Dn Transistor H H 0V X X off H H VTT VTT H nearly off H H VTT L L on L L 0V-VTT X X off
Maximum Ratings Note:
Storage Temperature ... -65oC to +150oC 1. Stresses greater than those listed under MAXIMUM Reference Voltage(2) .. -0.5V to +6.0V RATINGS may cause permanent damage to the device. This is a stress rating only and functional operation of the Reference bias voltage ... -0.5V to+6.0V device at these or any other conditions above those DC Input Voltage ... -0.5V to +6.0V indicated in the operational sections of this specification Control Input Votage(EN) ... -0.5V to+6.0V is not implied. Exposure to absolute maximum rating channel current (DC) ... 128mA conditions for extended periods may affect reliability. Input clamping Current ... -50mA 2. The input and input/output negative voltage ratings ESD: HBM Mode ... 4000V may be exceeded if the input and input/output clamp current ratings are observed.
VCC = 2.7 V to 5.5 V; GND = 0 V; TA = -40 C to +85 C; unless otherwise specified
Symbol Parameter Test Conditions Min. Typ. Max. Unit
VI/O Voltage on an input/output pin S1, D1, S2, D2 0 - 5 V SREF Reference voltage (1) SREF 0 - 5 V DREF Reference bias voltage (2) DREF 0 - 5 V VGREF Input voltage on pin GREF - 0 - 5 V I(pass) Pass switch current - - - 64 mA TA Ambient temperature - -40 - 85 oC PI4GTL2002
www.diodes.com
October 2018 Document Number DS40704 Rev 2-2 3 © Diodes Incorporated
