Datasheet Teseo-LIV3R (STMicroelectronics) - 4
Manufacturer | STMicroelectronics |
Description | Teseo ROM GNSS module |
Pages / Page | 30 / 4 — General description. Teseo-LIV3R. 1 General. description. 1.1 GNSS. … |
File Format / Size | PDF / 864 Kb |
General description. Teseo-LIV3R. 1 General. description. 1.1 GNSS. performance. Table 2. GNSS performance. GPS &. Parameter. GNSS
General description Teseo-LIV3R 1 General description 1.1 GNSS performance
Receiver specifications are the following: GPS L1C/A SBAS L1C/A QZSS L1C/A GLONASS L1OF BeiDou B1
Table 2. GNSS performance GPS & Parameter GNSS GPS & BeiDou Unit GLONASS
<32 <36 Cold start Warm start Time To First Fix (1) <25 <29 s Hot start <1.5 <2.5 Tracking -163 -163 Navigation(5) -158 -158 Reacquisition(6),(7) -156 -156 Sensitivity(2),(3),(4) dBm Cold start -147 -147 Warm start -148 -148 Hot start -154 -151 Max fix rate — 10 10 Hz Velocity accuracy(8) — 0.01 — m/s Velocity accuracy(9) — 0.1 — m/s Heading accuracy(8) — 0.01 — ° Heading accuracy(9) — 2.3 — ° Horizontal position Autonomous <1.8(10) <1.5(10) accuracy(10) SBAS <1.5(10) — m Accuracy of time pulse RMS 99% — — Frequency of time pulse — — — — Dynamic(12) <4.5g <4g — Operational limits(11) Altitude 100000 100000 m Velocity 600 600 m/s Altitude 18000 18000 m Operational ITAR limits(13) Velocity 515 515 m/s 1. All satellites at -130 dBm - TTFF at 50%. 2. Demonstrated with a good external LNA. 4/30 DS12821 Rev 2 Document Outline Table 1. Device summary 1 General description 1.1 GNSS performance Table 2. GNSS performance 1.2 Block diagram Figure 1. Teseo-LIV3R block schematic 1.3 Pin configuration Figure 2. Teseo-LIV3R pin layout 1.4 Pin out description Table 3. Teseo-LIV3R pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 3 Augmentation systems 3.1 Satellite-Based augmentation system 3.2 QZSS 3.3 Differential GPS Table 4. Supported RTCM message on Teseo-LIV3R 4 Assisted GNSS 4.1 RealTime AGNSS 5 Clock generation 5.1 Temperature-Compensated Crystal Oscillator (TCXO) 5.2 Real Time Clock (RTC) 6 I/O interfaces 6.1 UART 6.2 I2C 7 FW configuration 8 Power mode 8.1 Hardware standby 8.2 Software standby 9 Geofencing 10 Odometer 11 Regulatory compliance 11.1 CE certification for Teseo-LIV3R Figure 3. CE marking 12 Electrical characteristics 12.1 Parameter conditions 12.2 Minimum and maximum values 12.3 Typical values 12.4 Absolute maximum ratings Table 5. Voltage characteristics Table 6. Thermal characteristics Table 7. Power consumption 12.5 Recommended DC operating conditions Table 8. Recommended DC operating conditions 13 Mechanical specifications Figure 4. Teseo-LIV3R mechanical specification 14 Shipping information 14.1 Reels Figure 5. Carrier tape Figure 6. Teseo-LIV3R orientation Figure 7. Cover tape Figure 8. Plastic reel Figure 9. PB band 14.2 Packing cartons for reels 14.3 ESD handling precautions 14.4 Moisture sensitivity levels 15 Labeling information Figure 10. Labeling information of Teseo-LIV3R Table 9. Labeling information description 16 Reflow soldering profile Table 10. Soldering profile values Figure 11. Soldering profiles 17 ECOPACK® Appendix A Reference document Revision history Table 11. Revision history
