Datasheet NCSU334A(T) (Nichia) - 3
ManufacturerNichia
Description280nm Deep UV LED
Pages / Page20 / 3 — NICHIA STS-DA1-5547A RANKS. Item. Forward Voltage Radiant Flux Peak …
File Format / SizePDF / 634 Kb
NICHIA STS-DA1-5547A RANKS. Item. Forward Voltage Radiant Flux Peak Wavelength Rank. -Min Max Unit
NICHIA STS-DA1-5547A RANKS Item Forward Voltage Radiant Flux Peak Wavelength Rank -Min Max Unit
Item
-Min Max Unit
V 4.5 6.0 P14d22 64.6 76.8 P14d21 54.4 64.6 P13d22 45.7 54.4 P13d21 38.4 45.7 U280 275 285 mW nm * Ranking at TS=25°C.
* Forward Voltage Tolerance: ±0.09V
* Radiant Flux Tolerance: ±6.5%
* Peak Wavelength Tolerance: ±3nm
* LEDs from the above ranks will be shipped. The rank combination ratio per shipment will be decided by Nichia. 2
