Datasheet IRF7832 (International Rectifier) - 8
ManufacturerInternational Rectifier
DescriptionHEXFET Power MOSFET
Pages / Page10 / 8 — Power MOSFET Selection for Non-Isolated DC/DC Converters. Control FET. …
File Format / SizePDF / 193 Kb
Power MOSFET Selection for Non-Isolated DC/DC Converters. Control FET. Synchronous FET
Power MOSFET Selection for Non-Isolated DC/DC Converters Control FET Synchronous FET
IRF7832
Special attention has been given to the power losses The power loss equation for Q2 is approximated in the switching elements of the circuit - Q1 and Q2. by; Power losses in the high side switch Q1, also called the Control FET, are impacted by the R of the * ds(on) P = P + P + P MOSFET, but these conduction losses are only about loss conduction drive output one half of the total losses. 2 P = I × R ( ) loss rms ds(on) Power losses in the control switch Q1 are given by; + Q ( ×V × f) g g  P = P + P + P + P   loss conduction switching drive output + Qoss × V × f + × ×  Q V f ( ) 2 in  rr in This can be expanded and approximated by; *dissipated primarily in Q1. P = I 2 ( × R ) loss rms ds(on ) For the synchronous MOSFET Q2, R is an im-     ds(on) portant characteristic; however, once again the im- + I  × Qgd × V × f  + I  × Qgs2 × V × f  portance of gate charge must not be overlooked since  i in   i in  g g it impacts three critical areas. Under light load the MOSFET must still be turned on and off by the con- + Q ( ×V × f) g g trol IC so the gate drive losses become much more  significant. Secondly, the output charge Q and re-  oss + Qoss × V × f verse recovery charge Q both generate losses that  rr 2 in  are transfered to Q1 and increase the dissipation in that device. Thirdly, gate charge will impact the This simplified loss equation includes the terms Q MOSFETs’ susceptibility to Cdv/dt turn on. gs2 and Q which are new to Power MOSFET data sheets. The drain of Q2 is connected to the switching node oss Q is a sub element of traditional gate-source of the converter and therefore sees transitions be- gs2 charge that is included in all MOSFET data sheets. tween ground and V . As Q1 turns on and off there is in The importance of splitting this gate-source charge a rate of change of drain voltage dV/dt which is ca- into two sub elements, Q and Q , can be seen from pacitively coupled to the gate of Q2 and can induce gs1 gs2 Fig 16. a voltage spike on the gate that is sufficient to turn Q indicates the charge that must be supplied by the MOSFET on, resulting in shoot-through current . gs2 the gate driver between the time that the threshold The ratio of Q /Q must be minimized to reduce the gd gs1 voltage has been reached and the time the drain cur- potential for Cdv/dt turn on. rent rises to I at which time the drain voltage be- dmax gins to change. Minimizing Q is a critical factor in gs2 reducing switching losses in Q1. Q is the charge that must be supplied to the out- oss put capacitance of the MOSFET during every switch- ing cycle. Figure A shows how Q is formed by the oss parallel combination of the voltage dependant (non- linear) capacitance’s C and C when multiplied by ds dg the power supply input buss voltage. Figure A: Q Characteristic oss 8 www.irf.com
