Datasheet AL5822 (Diodes)
Manufacturer | Diodes |
Description | Adaptive 100/120HZ LED Current Ripple Suppressor |
Pages / Page | 10 / 1 — AL5822. ADAPTIVE 100Hz/120Hz LED CURRENT RIPPLE SUPPRESSOR. Description. … |
File Format / Size | PDF / 547 Kb |
AL5822. ADAPTIVE 100Hz/120Hz LED CURRENT RIPPLE SUPPRESSOR. Description. Pin Assignments. Top View. SOT26. Applications. Features
AL5822 ADAPTIVE 100Hz/120Hz LED CURRENT RIPPLE SUPPRESSOR Description Pin Assignments
The AL5822 is a 100Hz/120Hz LED current ripple suppressor for LED
Top View
lighting applications. Combined with a pre-stage APFC LED driver, the AL5822 circuitry can efficiently suppress the low frequency (100Hz/120Hz) LED current ripple from the APFC output, thus eliminate the low frequency flickering for various LED lamps. VIN 1 6 VLMT The AL5822 adopts high efficiency driving mechanism. It can automatically adapt to different LED chains’ voltage and current, to GND 2 5 VS
T
eliminate the LED current ripple, meanwhile minimize the power
C
consumption on the Power MOSFET. VC 3 4
U
VG The AL5822 has built-in protections, such as Over-Temperature-
D
Protection (OTP), Over-Current-Protection (OCP) and LED Short-Circuit
O
Protection (SCP).
R SOT26 P
The AL5822 is available in the SOT26 package.
W Applications E Features N
High Efficiency General LED Lamps Support Various Kinds of APFC Pre-Stage Circuit LED Power Modules Simplified External Bill of Materials (BOM) No Need for Magnetic Components Wide Output Voltage and Current Range Tuneable LED Current Ripple Ratio Flickering Free Built-In LED Short-Circuit Protection (SCP) Built-In Over-Current Protection (OCP) Built-In Over-Temperature Protection (OTP) SOT26 Package
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Note 3)
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds.
Typical Applications Circuit
APFC LED Driver LEDS R1 + R C1 VIN VLMT LMT1 1 6 GND 2 AL5822 5 VS C2 VC 3 4 VG Q1 C3 RLMT2 Rs AL5822 1 of 10 January 2019 Document number: DS41708 Rev. 1 - 2
www.diodes.com
© Diodes Incorporated
