Datasheet KP276A1201 (Infineon)
ManufacturerInfineon
DescriptiondTurboTMAP with SENT Output and Temperature Sensor Interface
Pages / Page27 / 1 — CONFIDENTIAL. KP276A1201 Digital Absolute Pressure Sensor. dTurboTMAP …
Revision01_00
CONFIDENTIAL. KP276A1201 Digital Absolute Pressure Sensor. dTurboTMAP with SENT Output and Temperature Sensor Interface
Datasheet KP276A1201 Infineon, Revision: 01_00
link to page 27
CONFIDENTIAL KP276A1201 Digital Absolute Pressure Sensor dTurboTMAP with SENT Output and Temperature Sensor Interface Features
• Increased media robustness for current automotive requirements • High accuracy pressure sensing (± 0.77% FSS) • Integrated signal processing for external temperature sensor • SENT protocol interface • Real 12-bit pressure resolution • Real 12-bit temperature resolution • Self diagnosis features • “Green” 8 pin SMD housing • Automotive qualified
Potential applications
• Automotive applications, Industrial control • Consumer applications, Medical applications
Product validation
Qualified for Automotive Applications. Product validation according to AEC-Q100/101.
The KP276A1201 is a miniaturized Digital Absolute Pressure Sensor IC based on a capacitive principle. It is surface micromachined with a monolithic integrated signal conditioning circuit implemented in BiCMOS technology. The sensor converts a pressure into a 12-bit digital value and sends the information via the SENT protocol (SAE J2716 revised April 2016). In addition, an interface for an external negative temperature coefficient (NTC) temperature sensor is provided. The temperature information given by the NTC is also digitized into a 12-bit value and transmitted with the SENT protocol. A special safety feature is the integrated diagnostic mode, which allows testing of the sensor cells as well as the signal path. This diagnosis is triggered by powering the device. The chip is packaged in a “green” media robust SMD housing. The sensor has been primarily developed for measuring manifold air pressure, but can also be used in other application fields. The high accuracy, high sensitivity and safety features of the device makes it a perfect fit for advanced automotive applications as well as in industrial and consumer applications.
Type Package Ordering Code Marking
KP276A1201 PG-DSOF-8-162 SP002627796 KP276A1201 Datasheet Please read the Important Notice and Warnings at the end of this document Revision 1.0
www.infineon.com
2019-01-25 Document Outline dTurboTMAP with SENT Output and Temperature Sensor Interface Features Potential applications Product validation Description Table of contents 1 Functional description 1.1 Pin configuration 1.2 Pin description 1.3 Block Diagram 1.4 Transfer function pressure 1.4.1 Pressure transfer function characteristics 1.4.2 Pressure accuracy 1.5 Transfer function temperature 1.5.1 Temperature transfer function characteristics 1.6 SENT interface 1.6.1 Physical layer 1.6.2 Data link layer 1.6.2.1 Nibble specification 1.6.2.2 Status and communication nibble 1.6.2.3 Enhanced serial message format 1.6.2.4 Enhanced serial message data 1.6.3 Pressure channel output codes 1.6.4 Temperature channel output codes 1.6.5 Diagnostic Error Codes 1.6.5.1 Signal out of range 1.6.5.2 Diag1 1.6.5.3 Diag2 1.6.5.4 EEPROM Check 1.6.6 Definition of Pressure signal path latency 1.7 External temperature sensor 1.7.1 Linearization of the external temperature sensor transfer function 1.7.2 Accuracy for NTC signal processing 2 Specification 2.1 Application circuit example 2.2 Application circuit example for EMC 2.3 Absolute maximum ratings 2.4 Operating range 2.5 Characteristics 3 Package information 3.1 PG-DSOF-8-162 Outline 3.2 Identification code Revision history Disclaimer
