Datasheet ACS715 (Allegro) - 3
ManufacturerAllegro
DescriptionAutomotive Grade, Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 2.1 kVRMS Voltage Isolation and a Low-Resistance Current Conductor
Pages / Page16 / 3 — Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current …
Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current Sensor IC. ACS715
Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current Sensor IC ACS715
Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current Sensor IC ACS715 with 2.1 kVRMS Voltage Isolation and Low-Resistance Current Conductor
DESCRIPTION (CONTINUED) leads (pins 5 through 8). This allows the ACS715 to be used in The leadframe is plated with 100% matte tin, which is compatible applications requiring electrical isolation without the use of opto- with standard lead (Pb) free printed circuit board assembly processes. isolators or other costly isolation techniques. Internally, the device is Pb-free, except for flip-chip high-temperature The ACS715 is provided in a small, surface mount SOIC8 package. Pb-based solder balls, currently exempt from RoHS. The device is fully calibrated prior to shipment from the factory. Selection Guide
Part Number Optimized Range, IP Sensitivity, Sens TA (A) (Typ) (mV/A) (°C) Packing*
ACS715ELCTR-20A-T 0 to 20 185 –40 to 85 ACS715ELCTR-30A-T 0 to 30 133 Tape and reel, 3000 pieces/reel ACS715LLCTR-20A-T 0 to 20 185 –40 to 150 ACS715LLCTR-30A-T 0 to 30 133 *Contact Allegro for additional packing options.
Parameter Specification
CAN/CSA-C22.2 No. 60950-1-03 Fire and Electric Shock UL 60950-1:2003 EN 60950-1:2001 2 Allegro MicroSystems 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com
