Datasheet ACS780xLR (Allegro) - 4
ManufacturerAllegro
DescriptionHigh-Precision Linear Hall-Effect-Based Current Sensor IC With 200 μΩ Current Conductor
Pages / Page25 / 4 — High-Precision Linear Hall-Effect-Based. ACS780xLR. Current Sensor IC …
File Format / SizePDF / 2.7 Mb
High-Precision Linear Hall-Effect-Based. ACS780xLR. Current Sensor IC With 200 µΩ Current Conductor. Functional Block Diagram
High-Precision Linear Hall-Effect-Based ACS780xLR Current Sensor IC With 200 µΩ Current Conductor Functional Block Diagram
IP+ VCC ACS780xLR To all subcircuits Master Current Supply Temperature EEPROM and Programming Sensor Control Logic Control Hall Current Drive Sensitivity Offset Control Control fset VOUT Tuned Amp Filter Cancellation Dynamic Of GND IP–
NC
Terminal List Table
4 IP+ 5 3 VOUT
Number Name Description
1 VCC Device power supply terminal 2 GND 2 GND Signal ground terminal 3 VOUT Analog output signal IP– 6 1 VCC 7 4 NC No connection, connect to GND for optimal ESD performance NC 5 IP+ Terminal for current being sampled 6 IP– Terminal for current being sampled
Pinout Diagram
7 NC No connection, connect to GND for optimal ESD performance Allegro MicroSystems, LLC 4 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com
