Datasheet AD7606-EP (Analog Devices) - 3
Description8-Channel DAS with 16-Bit, Bipolar, Simultaneous Sampling ADC
Pages / Page15 / 3 — Data Sheet. AD7606-EP. GENERAL DESCRIPTION
File Format / SizePDF / 279 Kb
Data Sheet AD7606-EP GENERAL DESCRIPTION
The AD7606-EP1 is a 16-bit, simultaneous sampling, analog-to- The input clamp protection circuitry can tolerate voltages up to digital, data acquisition system (DAS) with eight channels. The ±16.5 V. The AD7606-EP has 1 MΩ analog input impedance device contains analog input clamp protection, a second-order regardless of sampling frequency. The single-supply operation, antialiasing filter, a track-and-hold amplifier, a 16-bit charge on-chip filtering, and high input impedance eliminate the need redistribution successive approximation analog-to-digital for driver op amps and external bipolar supplies. The AD7606-EP converter (ADC), a flexible digital filter, a 2.5 V reference and antialiasing filter has a 3 dB cutoff frequency of 23 kHz. The reference buffer, and high speed serial and paral el interfaces. flexible digital filter is pin driven, yields improvements in SNR, The AD7606-EP operates from a single +5 V supply and can and reduces the 3 dB bandwidth. accommodate ±10 V and ±5 V true bipolar input signals while Additional application and technical information can be found sampling at throughput rates up to 150 kSPS for al channels. in the AD7606 data sheet. 1 Protected by US Patent Number 8,072,360. Rev. 0 | Page 3 of 15 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
