Errata Sheet AD7994, AD7993 (Analog Devices)
Description4 Channel, 12-Bit ADC with I2C Compatible Interface in 16-Lead TSSOP
Pages / Page1 / 1 — 4 Channel, 12-/10-Bit ADCs with I2C. Compatible Interface in 16- Lead …
RevisionA
File Format / SizePDF / 53 Kb
4 Channel, 12-/10-Bit ADCs with I2C. Compatible Interface in 16- Lead TSSOP. Errata Sheet. AD7994/AD7993. AGND. AD7994. SCL. SDA
Errata Sheet AD7994, AD7993 Analog Devices, Revision: A
a
4 Channel, 12-/10-Bit ADCs with I2C Compatible Interface in 16- Lead TSSOP Errata Sheet AD7994/AD7993
Please be advised that it was necessary to change the pin-out diagram for the AD7994/AD7993 ADCs. Please discard any pin-out information from AD7994/AD7993 data sheets up to and including Rev PrD. Packaged material may be identified by the date code; parts with date code 0311 have the old pin-out and will be no longer manufactured. All other date-coded material will be manufactured according to the new pin-out diagram which is shown below.
AGND
1 16
AGND AGND
2
AD7994
15
SCL AGND
3 14
SDA AGND
4
TOP VIEW
13
ALERT VDD
5 12 CONVST (Not to Scale)
REF
11
AS IN
6
V
10
IN1
7
VIN2 V
9
V IN3
8
IN4
REV. A Sept 2003 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties
which may result from its use. No license is granted by implication or
Tel: 781/329-4700 World Wide Web Site: http://www.analog.com
Fax: 781/326-8703 Analog Devices, Inc., 2003
