Datasheet VDRUS (Vishay) - 6
ManufacturerVishay
DescriptionVDR Metal Oxide Varistors Ultra Surge High Operating Temperature 125°C
Pages / Page15 / 6 — VDRUS Series. VARISTORS ON TAPE IN AMMOPACK. VDRUS07. VDRUS10. VDRUS14. …
File Format / SizePDF / 227 Kb
VDRUS Series. VARISTORS ON TAPE IN AMMOPACK. VDRUS07. VDRUS10. VDRUS14. TYPE. Ø 7 mm. Ø 10 mm. Ø 14 mm. 115 V to 510 V. 115 V to 550 V
VDRUS Series VARISTORS ON TAPE IN AMMOPACK VDRUS07 VDRUS10 VDRUS14 TYPE Ø 7 mm Ø 10 mm Ø 14 mm 115 V to 510 V 115 V to 550 V
VDRUS Series
www.vishay.com Vishay BCcomponents
VARISTORS ON TAPE IN AMMOPACK VDRUS07 VDRUS10 VDRUS14 TYPE Ø 7 mm Ø 10 mm Ø 14 mm 115 V to 510 V 115 V to 550 V 115 V to 550 V
Straight leads H = 18 mm - - ASE H = 20 mm ASE ASE - See drawing: taped version with straight leads Kinked leads H0 = 18.25 mm AME AME AME H0 = 16 mm ALE ALE ALE See drawing: taped version with kinked leads
Packaging quantities
115 V to 210 V 1500 500 500 230 V to 510 V 1000 500 500 550 V - 400 400 
DIMENSIONS OF AMMOPACK
in millimeters
52 or 55 max. 340 max. 250 max.
Revision: 18-Jun-2019
6
Document Number: 29185 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
